Jump Seat Replacement
Old Nov 29, 2018 | 08:09 PM
ModelTshop's Avatar
ModelTshop
As I've been looking for a Supercab, I've come across a couple that meet everything that I'm looking for except they have rear jump seats instead of a rear bench seat. Is it possible to replace them with a factory bench seat? Has anyone ever done this? What parts are needed? Thanks in advance for the help.
Old Nov 29, 2018 | 10:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Nov 29, 2018 | 11:37 PM
four-sixty-power's Avatar
four-sixty-power
The hardest thing to source will be the latch support that the latch bolts to, that holds the back of the benchseat up, as it is spot welded to the cab. I swapped a bench seat in and removed the jumpseats, all the holes and welded captured nuts were existing for the benchseat parts to bolt into, except of course for the weld-in latch support.
Old Nov 30, 2018 | 03:21 PM
somethingclever's Avatar
somethingclever
you can use a latch support from up to 1996 extended cab truck....and the seat too.
That is what I did for my truck.
Don't let the rear jump seats hold you back at all.
stercorarius
Jul 11, 2013 02:55 PM
Furian
Aug 15, 2009 11:37 AM
justdave
1997 - 2003 F150
Jun 18, 2005 11:50 PM
tcooper3
Apr 3, 2004 01:37 PM
