chip vs exhaust break
Old Sep 26, 2003 | 11:03 PM
billytucker1's Avatar
billytucker1
I have a 2002 PSD with A/T. I am looking at getting either a braking chip or an exhaust break like BANKS. Which is better and does either one void the warranty. I would appriciate any suggestions. Thanks Billy
Old Sep 29, 2003 | 09:02 AM
JMorton's Avatar
JMorton
I've never heard of a breaking chip, the Banks brake can affect warranty though.
I wired up the EBPV that is already on the truck as an exhaust brake and it works great, cost about $25 as opposed to several hundred for the Banks unit and only took a couple hours to do. Try it and save yourself some money!! Check out this link for more info.
http://hometown.aol.com/jzettel73/EBPV_Brake.html
Old Sep 30, 2003 | 12:03 AM
jarman62000's Avatar
jarman62000
I want to try this EBPV brake. Just one question from looking at the instructions and the wiring diagram. Where do I find the tourque convertor lockup, the purple wire with the yellow tracer?
Old Sep 30, 2003 | 07:56 AM
JMorton's Avatar
JMorton
I didn't use it and mine works just fine. I would also only use a single position switch if I had it to do over again and wire it to the throttle pedal so its activated when you let off of the throttle. I added that feature to mine and that's the only position I ever use now. I never use the always on position at all.
Go and search "DIY Exhaust Brake" and you can read for a couple of days on this subject. A lot of guys there have done this and that's where I got the idea. If you need any more help, let me know and I'll try to put together a newer diagram of the way to do it with a single position switch and a relay for the throttle pedal.
Old Sep 30, 2003 | 08:52 AM
johnsdiesel's Avatar
johnsdiesel
Why did you start a new thread? Here's your original:
https://www.ford-trucks.com/forums/s...hreadid=156462
