Sponsored by: Real Truck
Code P0181. Where is fuel temp sensor A
Old Nov 20, 2018 | 11:16 AM
Horsepower_Hooligan's Avatar
Horsepower_Hooligan
Question Code P0181. Where is fuel temp sensor A
So, I'm not 100% sure that I need to replace the sensor yet, as I don't know if it's actually bad. I read that sometimes this code can be thrown if you plug the block heater in above 0F, which puts the difference between the CAC temp and the fuel temp out of its threshold. Apparently it's supposed to detect that you had the block heater plugged in, but sometimes it doesn't above 0F.
That being said, in case it actually is bad in my case, where is it on the truck, and where can I find the part?
Old Nov 20, 2018 | 04:30 PM
Horsepower_Hooligan
So I did a bunch of digging myself and found where it's located, as there's not really a clear answer out there, unless you dig for awhile like I did. I've attached pictures of where it's located. It's right next to the fuel pressure switch, apparently. Also, the P/N from Ford is BC3Z9F951A.
Stew1022
6.7L Power Stroke Diesel
Dec 5, 2017 10:06 PM
RA12726
Ford In-Vehicle Tech
Jan 18, 2017 01:26 PM
EALightingSolutions
2009 - 2014 F150
May 17, 2015 09:45 PM
graeaglecrawler
Nov 18, 2011 02:10 PM
WhiskeyRider
Jan 31, 2010 06:01 AM
