sound Deading
Old Nov 18, 2018 | 04:20 PM
Tex51's Avatar
Tex51
sound Deading
Has anyone tried this spray foam to seal up the pockets behind the seat in each corner of the cab. Those pockets in the corner of the cab where when something falls down in those corners it is usually lost. I am using Hercules bed line on the floor of my cab and will be using something like that on the ceiling of my cab and inside my doors. But I wanted to seal up those deep pockets in the corners of my cab and this spray expanding foam looks good.
Old Nov 18, 2018 | 07:35 PM
LACzar's Avatar
LACzar
I would be concerned with moisture being trapped by the foam and eventually rusting. _ Tony.
Old Nov 18, 2018 | 07:55 PM
fe390pc's Avatar
fe390pc
There are two or three drains in that area in each corner. I just went through cleaning my cab out and found that two of mine were plugged and starting to cause rust issues. I would make panels to cover up the access and not fill with anything.
Old Nov 22, 2018 | 02:02 PM
Tex51's Avatar
Tex51
I found the drain holes and after a few hours I got all the trash out of both of corners. I am thinking I will put the rust-o-leum paint primer and then a good coat of red glossy rust-o-leum paint in the corners. I was thinking about the moisture build up. I also see where if you got in high water it will come right in the cab thru the holes in those corners. I may put some bed liner spray in there to help with the noise coming from that area too.
Thisguy65
May 22, 2017 09:26 AM
anyexcuse
19
Aug 4, 2014 12:00 PM
megawatt00
Paint & Bodywork
Feb 16, 2014 07:35 AM
roadrash63
15
Sep 29, 2012 05:30 AM
FESTER1st
Jun 17, 2008 02:42 AM
