1985 f250 460 problems
Old Nov 16, 2018 | 12:11 AM
Shane Peterson's Avatar
Shane Peterson
Hi there thanks for the add. well my 460 will run when in park. with really light pops out of the carb and will slightly miss.when in drive it runs bad and trying to die it will not idle the dash shakes while in gear that bad.until its up to temperature.then it pop in and out on all 8 cylinder's doing the same thing i have the timing on point with out wires crossing rotor on number one tdc with number 1 cylinder up.new list fuel filter an pump wires plus ignition box on driver side wheel well holly 600 floats on point air mixter also 2 out on passenger side 1 1/2 on the driver side all 8. plugs look the same when pulling them out gabs at 45 tested every plug wire on a different rig. and they check out good.iv put tranny fluid in all cylinders for most compression to see if i have a dead hole no change it ran the same. So im thinking bad cam or valves ?.i cant cover one pipe at the back of the truck but the other is pushing in an out from the driver side bank not all the time
Old Nov 16, 2018 | 12:22 AM
Shane Peterson
Hi there thanks for the add. well my 460 will run when in park. with really light pops out of the carb and will slightly miss.when in drive it runs bad and trying to die it will not idle the dash shakes while in gear that bad.until its up to temperature.then it pops a in and out on all 8 cylinder's doing the same thing i have the timing on point with out wires crossing rotor on number one tdc with number 1 piston up.new list fuel filter an pump wires plus ignition box on driver side wheel well holly 600 floats on point air mixter also 2 out on passenger side 1 1/2 on the driver side all 8. plugs look the same when pulling them out gabs at 45 tested every plug wire on a different rig. and they check out good.iv put tranny fluid in all cylinders for most compression to see if i have a dead hole no change it ran the same. So im thinking bad cam or valves ?.i cant cover one pipe at the back of the truck but the other is pushing in an out from the driver side bank not all the time
Old Nov 16, 2018 | 06:28 PM
FordExplorerFanatic's Avatar
FordExplorerFanatic
You have the firing order wrong.
Old Nov 18, 2018 | 12:18 AM
Skitter302's Avatar
Skitter302
Bad timing,
Wrong firing order,
bad pick up signal from dist
rsm688
30
Jun 16, 2015 09:25 AM
jgc2521
Aug 15, 2010 03:41 PM
10quadx
Oct 22, 2009 11:59 AM
OldBlue68
Jul 24, 2008 12:08 PM
007bronco
1978 - 1996 Big Bronco
Mar 12, 2004 11:27 AM
