Need to find correct computer (pcm)(ecm)
Old Nov 15, 2018 | 11:24 PM
BegleyA's Avatar
BegleyA
Hello all! I am a new member and ive read alot of good information off here and thought i would join up. Ive owned and drove a Ford since i was 16 and now im 36. Currently i have a 94 f150 4x4 351 5 speed. Truck was a 4.9 from the factory but done a 351w efi swap back in 2001. 6 in lift 456 gears extended radius bars custom off road bumpers. Ive owned many rangers also. My other Ford is a 91 F-350 2wd cab n chassis 11ft flat bed electric over hydraulic dump. 351w zf5-42 transmission. This truck is why i have joined to see if anyone can help me figure out the correct ecm computer for the truck. Upon investigating the computer, the past owner had swapped it out for some reason that i dont know for a automatic ecm. I have tried finding it thru Ford dealerships with no luck. I have the Vin# and the calibration # off the door jam. Thanks for reading.
Old Nov 16, 2018 | 03:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Why did you start another thread for the same issue?
Old Nov 16, 2018 | 04:24 AM
BegleyA's Avatar
BegleyA
I thought the first 1 I made as (new member) did not list my question. If 1 or both that needs to be deleted that will be ok.
Old Nov 16, 2018 | 04:29 AM
BegleyA's Avatar
BegleyA
How can i delete the first 1? Thanks
Old Nov 16, 2018 | 12:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You cannot ask tech questions in the New Member Introduction forum. It's just for saying hello...
BegleyA
Nov 14, 2018 10:50 PM
cdonough
Mar 2, 2004 09:58 PM
