5 Star tuning for you gasser guys
just got my tunes loaded last night. I went with 89 tow and 91 performance. I definitely feel some extra power. My Excursion has 4.30 gears so it had decent off the line pull. With the 91 performance the engine pulls much stronger to red-line. I'll have to see if there is an increase in MPG.
I don't tow over 70mph, so wondering what my RPMs would be with either the 4.30s or the 4.56s and my 285 tires? Have no need to go as large as the 35s ever again. Just adds extra rolling resistance and weight. I might be in the minority in this group because I can't stand lifted vehicles.
My V-10 EX is a dedicated tow rig for an 11K TT, I run 5Star tunes al the time, mostly the 89 Octane Performance tune while towing. I sprung for the Banks headers and Y pipe, Aeroturbine 3030XL muffler, 4.88 gears and 35" tire's (effective ratio of 4.39). I love the tunes (87 Economy, 87 Tow, 87 Perf, 89 Tow and 89 Perf) I like the Perf tunes for my towing need's better than the actual Tow tunes, they are a better match for my driving style. Have not run with the stock tune in years. For a hard working V-10 gears are the biggest performance mod you can do (short of a custom turbo/super charger setup) and good custom tunes are next on the performance list.
2004 V-10, no engine mods other than Gibson shorties and the 5 Star Y-pipe. The rest is stock. Factory tire size with the 3:73 rear. This will be my DD as well as Tow Vehicle. Trailer fully loaded will be about 7-8K. I'm retired, so do not do much actual DD activity. When I do, I tend to put my foot into it more than not. Living in Florida, I will mostly have to deal with the bridges and not the mountains, though I am looking forward to at trip towing into the Smokies soon. I'd like to run regular, but will put higher in if needed for towing in the mountains.
How many tunes? 87 Perf and 89 Perf? Maybe throw in an 87 Eco?
Also not planning on towing above 65-70 mph
I got 16.3mpg empty and about 8.5 towing. Stock V10 with 3:73 gear, factory size tires. When you say you run the 89 Perf tune, are you also running 89 octane to match? I buy my gas at one of the wholesale clubs and they only offer 87 and 93, no mid-grade. The prices are usually the lowest in the area.
I'm interested in hearing what the Y pipe did for your V10. Then to hear what the gear change does with the same tires. I'm going to do both Shorties and the Y pipe, not sure I'll do a gear change.
I have a 2000 V10/4wd EX and run the 5Star on 87Perf all the time, towing or not. I bought the Y-pipe and have it scheduled to be installed tomorrow, so it'll be nice to see what kind of difference it will have over the original Rams Horn design and my 3.73 gearing with 285 tires. When I bought it last year, it was running 35s and no tuning. Slowly getting it where I want it to be, but I think my butt-dyno will likely see the biggest effect when I do a 4.30 re-gear.
Ok, I'm going to pull the trigger on some 5Star tunes now that the 2 for 1 sale is on. As many have mentioned, they like the Perf tunes over the Tow tunes. So, biased on the following, what do you think I will need, and, would it be worth it for a custom tune?
I bought my tuner from 5Star during a sale where I got the tuner and 5 tunes for a pretty good price, so I got the 87 Econ, Tow, Perf and the 89 Tow and Perf. These days as the EX is pretty much a dedicated tow rig I only use the 87 and 89 Perf tunes, but mostly the 89 perf and matching 89 Octane gas. If your station only has 87 and 93 you could split your fillups between the two, which would give you a tank of 90 Octane if you want to run some 89 tunes. The tunes do advance the timing a good bit so running a hotter tune with lower Octane gas could lead to some pinging and detonation. What is the current sale offering? If the number of tunes is limited I don't think I would get the Econ tune as I'm getting some of the best mileage that I've seen on the 89 Perf tune. (14.5 MPG at 65 MPH)
What tires do you have on the car trailer? Some ST tires are speed limited to 65 MPH and are only good for 3/4 years or less, my factory ST tires on the TT didn't even make it to the 3 year mark before I had two failures. Many of the newer ST tires are being built better than the common China bombs and are rated for higher speeds and seem to be aging a bit better.
With your RWD EX I would seriously consider the gear change, just look for a factory 4.30 Sterling axle and swap it out with your 3.73 axle, it should be pretty cheap and fairly easy to do and it will make for a better tow rig and a better performing daily driver with almost no downsides! maybe a 1 MPG drop in daily mixed, but some report even better in town mileage and you should see an improvement in towing MPGs, I saw an almost 25% towing MPG increase going from 3.73 to 4.88s pulling 9,500lbs on 32" tires, that was all before I had the tunes!
I've been on-call for the hospital and have worked the last 42 days straight without any time off, so........I have yet to actually make a road trip with it since the Y-pipe install. At idle, there is no difference in exhaust tone. However, once you step on it or are driving at a steady 2000 rpm, you can hear a difference in the tone. Not throaty or a low growl, but maybe a hair raspy. Hard to give a written response to its sound without actually having a video or audio clip to go with it, but there is definitely a difference in both the tone and the db level while underway. Butt-dyno didn't detect any noticeable gains, but at best, we're only talking 10-15hp on a vehicle that weighs in close to 8k lbs. Once my new employee is trained and pulling shifts on her own, my plan is to hitch up to the sled trailer and head for the mountains for a good weekend ride and a soak in the hot springs. I'll know then if I've added any additional pulling power.
The reason I like the Perf tunes for my towing chores over the actual Tow tunes is that the Tow tunes are too aggressive when it comes to downshifting, they have it drop out of OD too early when the engine is still making enough power to hold OD on most Interstate grades (in my current configuration). The Perf tunes will allow for more throttle opening while holding OD and this suits my driving style and configuration better, I'm happy to allow a bit of speed to bleed off on a climb if it will allow me to stay in OD as that nets better MPGs (and I still get where I'm going! ). But I'm running with an effective ratio of 4.39 vs your stock 3.73 ratio, you are pulling 4500 lbs less with a lower trailer and I don't know what driving style you favor, so I really don't know if the Tow or Perf tunes would serve you better. The more aggressive Tow tunes would be a better choice for someone who wants to maintain the same speed (up to the power train limits) on mountain climbs. So give it a little thought on what you feel would be the better match for you and your equipment. I've had this conversation with 1EXCamper who also tows heavy with 4.30 gears and he tried the Perf tune and didn't care for it, so he went back to his favored Tow tunes, its a personal choice based on a few factors.
Though I do like the power, when towing I do not need to maintain speed while going up a good grade. Let it throttle up, downshift, slow a bit. I do not feel the need to be so aggressive and maintain cruising speed while climbing. I don't want it to slow to a crawl either. Sounds like both of us are on the same page here.
I'm going to go with the 3.73 and stock tires for now. As mentioned, I'm pulling less weight than you and the trailer is much lower, as seen in my sig picture. Non loaded pure highway I got 16.4 mpg. I will see how things go with the Shorties, Y pipe and tunes to see if I really need to do a gear change. Maybe if one drops in my lap for a good price..... :-)
So you are only running the Regular and Mid grade Tunes, not the Premium? Is there that much of a difference between the Regular and Mid grade Tunes when you run the matching octane gas?
My trailer still has the tires that came with it, just going on 2 years old. ST225/75-15, Speed Rating L (75MPH) China made. :-( I keep tire covers on them to keep the sun off. Luckily my brother owns/runs a boat repair business and I can get good tires for a good price. I plan on traveling with 2 spares for the trailer.
No hurry on the Y pipe. I'm going to do the Shorties and Y pipe anyway. Just wondering what to expect. Thanks for getting back to me.
Tom, as always, so much information. Thank you.
I'm going to go with the 3.73 and stock tires for now. As mentioned, I'm pulling less weight than you and the trailer is much lower, as seen in my sig picture. Non loaded pure highway I got 16.4 mpg. I will see how things go with the Shorties, Y pipe and tunes to see if I really need to do a gear change. Maybe if one drops in my lap for a good price..... :-) .
So you are only running the Regular and Mid grade Tunes, not the Premium? Is there that much of a difference between the Regular and Mid grade Tunes when you run the matching octane gas? .
My TT's stock 15" E rated STs came apart internally and just started to tear when I found them (different trips) and fortunately did not cause any trailer damage. I upgraded to 16" all steel Sailun STs in load range G (110 PSI), that required swapping in 8 lug hubs, new larger bearings and 8 lug 16" high pressure wheels and I installed an upgraded heavy duty shackle kit (twice as thick as stock) and wet bolts with bronze sleeves (to replace the stock PLASTIC sleeves) in all the suspension points. Those tires (beasts!) have earned an excellent reputation in the RV world and served us very well for the past 2 years.
TPMS Solar Power Universal, Wireless Tire Pressure Monitoring System with 4 DIY Sensors, Real-time Displays 4 Tires' Pressure and Temperature
#28
I have the 5200 torsion axels, simplifies the suspension. I'm also running a TPS system on the trailer tires. the little dash pod display has no problem reading the senders (pressure and temp) on the trailer's tires.
#29
Quick update: Purchased 2 tunes, got 4 on the Holiday 2 for 1 sale. I got the 87 Eco, 87 Perf, 89 Perf and 93 Perf
I updated my X4 and had all kinds of troubles. Ended up calling SCT and have the tech remote into my computer and completely re-program my X4. Something about the 04's and earlier not having the VIN in the ECU.
Anyway, 1st thing I notice is the early upshifts. Next is the lack of downshifting, though I have only gone about 3/4 throttle. After a week of driving, I see it is getting better mileage though I would like to finish off 1 tank before getting a true reading.
#30
