Diesel engine swap
Old Nov 13, 2018 | 10:27 PM
Erics940's Avatar
Erics940
Diesel engine swap
so im looking into swapping a 7.3 powerstroke with a zf5 transmission into a 77’ crew cab f250 i just wana pick some knowledge from people that did previous diesel engine swaps in these year trucks
Old Nov 13, 2018 | 11:48 PM
ford390gashog's Avatar
ford390gashog
Been there and have done it multiple times, what do you want to know exactly? If the truck is 2wd you better be a good fabricator as you will be making a custom oil pan and doing modifications to the front cross member.
Old Nov 14, 2018 | 12:04 AM
Erics940's Avatar
Erics940
Its is already 4wd drive and it is manual
Old Nov 14, 2018 | 12:07 PM
ford390gashog
Well that is a bonus, so now just gut the running gear. The ZF will need a hydraulic clutch setup so you will have to get creative with the pedals. I use the 2nd gen dodge master cylinder and firewall bracket with the OBS 7.3 hose and slave.
ggibson1970
Nov 7, 2018 05:56 PM
Coleton_henry
17
Nov 1, 2017 12:56 PM
John Isaacson
May 22, 2013 07:13 PM
pvail79
Oct 23, 2012 06:42 PM
SMT
May 29, 2001 07:04 PM
