Drive Shaft ???
Old Sep 26, 2003 | 03:31 PM
javi2001's Avatar
javi2001
Lightbulb Drive Shaft ???
Hi all, I want know what kind of drive shaft is used on this configuraion:
F150 4X4
Engine 300, 6L
E4OD tranny
1356 BW Electric shifth Transfer case
3.55 Front/Rear axel
I want know if it use double cardan at Tansfer case side as used on Bronco OR single cardan. How long it is?
Thanks in advanced,
Old Sep 26, 2003 | 06:29 PM
Wolfman2405's Avatar
Wolfman2405
It should be the same as the Bronco, The Chiltons has both the Bronco and F150 4x4's listed as a double cardan.
Old Oct 1, 2003 | 09:17 AM
javi2001's Avatar
javi2001
Well, thanks for the info. A guy who has same configuration, (tranny is manual) sent me 3 pictures and this is single cardan, but I'm not sure yet, because E4OD tranny is longer than mazda manual, isn't it?
Regards;
Old Oct 1, 2003 | 12:57 PM
Wolfman2405
you got me there, I don't know, I know that my Bronco is 302 4X4 AOD tranny and it uses a double, I would imagin that the pick up in question would use a double but again I don't know, maybe someone on here with more knowledge than me can speak up.
Sorry I could'nt be more help.
Old Oct 3, 2003 | 09:41 AM
javi2001's Avatar
javi2001
Bronco use double cardan because distance betwen front and rear wheels is too short, then variation in angle at drice shaft require double cardan.
F150 is longer thatn Bronco, so probably it doesn't use it, thats why I'm in doubt.
Regards;
Old Oct 3, 2003 | 10:45 AM
KJKozak2's Avatar
KJKozak2
Regards;
My 78 F150 reg. cab SWB 4x4 has a double. But it also has a 460 and c6 if that makes a difference.
My 79 F150 reg. cab SWB 4x4 also has a double with a 351m and 4spd manual.
Kevin K.
