Oil Plug.......
Old Sep 26, 2003 | 02:54 PM
Fal Grunt's Avatar
Fal Grunt
Oil Plug.......
Ok, im new, and massively in experienced. WHERE THE H*&^ is the oil plug to drain the oil? I think I found it...... a bolt on the underside but im afraid that it might not be the oil plug, I need as detailed description of location and look as possible. Thanks -myers
Old Sep 26, 2003 | 03:30 PM
grapegravy's Avatar
grapegravy
Should be the only bolt on the oilpan. Pull it and see if oil comes out
Old Sep 26, 2003 | 11:26 PM
79_custom's Avatar
79_custom
It should be either on the drivers side of the oil pan or at the main back of the slump at the bottom in the center..
