kick down rod
Old Nov 11, 2018 | 01:13 PM
beartracks's Avatar
beartracks
kick down rod
Need a kickdown rod or maybe a LOKAS cable unit.
Old Nov 11, 2018 | 04:32 PM
85e150's Avatar
85e150
Permission granted, go ahead and get one.
Old Nov 12, 2018 | 09:17 AM
beartracks's Avatar
beartracks
Thousands of comedians out of work and here you are.
Old Nov 12, 2018 | 12:24 PM
85e150's Avatar
85e150
Thousands on line ready to help, but nothing to work with in post 1. Year, make, model, engine, trans?
Old Nov 12, 2018 | 01:11 PM
beartracks's Avatar
beartracks
77 C-6, thinin about a LOKAR cable but thier pictures are not clear about the install. Also have a Speed demon carb with the standard Ford auto linkage.
Don't take offence. I'm an equial opportunity offender. I'll eventually get around to everyone.
Old Nov 12, 2018 | 01:52 PM
85e150's Avatar
85e150
Have you seen:
http://www.lokar.com/assets/instruct...ickdownKit.pdf
Couple of pictures here:
https://www.ford-trucks.com/forums/9...linkage-2.html
Lots more but mostly covering the same territory.
Old Nov 13, 2018 | 09:33 AM
beartracks's Avatar
beartracks
Thanks, I managed to rescue mine for now. It's amazing what you can do with a hammer, a piece of pipe and some wrinkle black.. I'll eventually use LOKAR probably.
Old Nov 13, 2018 | 09:35 AM
beartracks's Avatar
beartracks
In the link from LOKAR the C6 picture is reversed or something. Don't want to use thier throttle cable.
Old Nov 13, 2018 | 03:49 PM
85e150's Avatar
85e150
Could it be a car vs. truck shift lever? One points up, the other down.
tallinboy
Sep 23, 2010 11:55 PM
85 Stepside
24
Oct 12, 2009 10:54 PM
1995sho
Sep 10, 2007 08:29 PM
60FordDriver
Aug 22, 2005 02:37 PM
