Selectable lockers will always be better than limited slips. I ran Eaton E-lockers in my jeep and I'm thinking about adding one to the front diff of my F250. ARB lockers are good too but require an air source and tubing.
Which which one of those lockers air or e would be more reliable in your opinion
Air lockers have their place, I have them in my Jeep also but they also have their limitations. A Truetrac in your truck will serve you far better than a true locker. The Truetrac doesn’t wear out, no speed limitations, excellent road manners and it’s automatic. I put the Truetrac in my 2wd truck almost a year ago it has worked flawlessly.
You know how ornery a locked rear end handles on icy Snowy Road
I'd say they're both equally reliable. An air line leak would be a little harder to fix, in my opinion, versus resolving a wire or replacing a fuse. That's just my opinion though. I'm sure others prefer the ARB over the e-locker. I prefer the e-locker.
Hands down the most reliable lockers are auto lockers like the Detroit or Grizzly. They are all mechanical and don't need cables, electric, or air to operate.
Agreed Detroit in the rear is golden never an issue. Lockright in front but may change for a grizzly.. it works but noisy.
I guess it depends if you want the ultimate traction. I plow and have a tree service I need a tractor and it delivers..
What he said: donkey. lol
