AFE 5 inch material question
Old Nov 7, 2018 | 08:45 AM
Jose Miranda's Avatar
Jose Miranda
I see that AFE has a 5inch dpf back pipe which is really all i need. But i see they have a stainless steel and then an aluminized steel which is cheaper. What’s the difference? Material quality? What can go wrong w the alumized that can’t with the stainless?
Old Nov 9, 2018 | 06:13 PM
Overkill2's Avatar
Overkill2
If you live in a dry climate, go for the aluminized one. If you live where it gets cold and they use salt on the roads in the wintertime, go for stainless steel. It has nickel in it that will resist rusting, how much depending on what grade it is. There could be other stuff in it also. I'm not experienced with make up of stainless and the grades. You can do some research online for that.
stroken
Dec 12, 2008 03:30 PM
killforfood
Dec 10, 2008 11:24 AM
bneafus
Mar 30, 2008 03:14 PM
walleye
Jun 21, 2007 11:42 PM
Dalamatition
Exhaust Systems
Sep 14, 2004 10:08 PM
