***2018 Keyless Entry Fuse Location***
Hello all, I have access to the 2018 F-150 Owners Manual both revision numbers one and three.
My vehicle was opened last night via the Keyless Entry pad located in the drivers side door. Unfortunately my factory code is super simple, I won't go into it's simplicity, however I would like to know if anyone might know which fuse I could pull and remove to disable the Keyless Entry pad?
1FTEW1EP1JKC72367
Kind regards,
John from Alaska....
1FTEW1EP1JKC72367
Kind regards,
The Service Manager was kind enough to email me the documentation from the Factory DVD regarding the door panel removal and wiring loom disconnection point for the Keyless Entry, tell me a little bit more about this "forscan"? Is it a Ford application or aftermarket device?
The door panel removal and wiring loom disconnect would be my last option....
1FTEW1EP1JKC72367
Kind regards,
1FTEW1EP1JKC72367
Kind regards,
Here is some more info about Forscan. Link to Forscan usage & capabilites = Forscan Tutorial Forscan coding spreadsheet = F150 forscan doc Where to get forscan = Forum & Activation
Since I can't remember anybody asking on how to disable the keypad, I don't think that is going to be documented in the Spread sheet. You are going to have to find it your self. I would start looking at the BCM (Body control module), That maybe the module that controls it. Also may have to signup for this forum Forscan Forum entry
It is extremely large. Again don't remember seeing anybody doing what you want, but maybe somebody has. It will take you a couple of days going thru that entry.
Good luck
Good luck
I learned something new today because I just assumed that when the user code is changed, the factory code is also changed to the new user code.
Very interesting.
Good luck
Good luck
