7.3 Idi Non Turbo Runaway
.I have a 1994 F-Super Duty with the 7.3idi Non Turbo that we recently rebuilt the engine in. We did a full rebuild pistons and everything put it all back together and now when we start it, it idles great nice and smooth no issues. But as soon as we touch the throttle to rev it up it runs away. We have all new injector lines o rings everything it doesn't smoke like a stuck injector when its idling or show any signs of stuck injector. We have tried using 2 injector pumps that were known good when we removed them off the other motors. Timing is all in check just don't understand why it runs away once we hit the throttle. Any help would be appreciated.
That likely just means that it's burning oil efficiently. No power to the pump, no flow to injectors.
Edit: If the covers have been off the pumps, they can be put on to cause a runaway / failure to shutoff with key condition im told. I personally dont see how you can do it, but apparently its happened.
It doesnt puke oil or even smell like its burning any oil, its a fully rebuilt engine sent the heads off had them pressure checked milled valve job done new valve seals everything bottom end had the block pressure checked new pistons and rings new rod main bearings new cam new cam bearings literally everything has been rebuilt on this motor its a tight motor if its picking up oil from somewhere how? and where? a new motor shouldnt have these issues. The injector pump has not been taken apart at all we had it running on another motor a couple days before putting it on this one same with the other injector pump we tried both we had running on other motors shortly before installing them on this one
That is one hell of an anomaly... from what youre saying, id say it has to be fuel / vehicle related then. Sticking throttle cable and FSS not shutting off? With air cleaner off, throttle cable off, move the lever by hand, let me know if it still tries to run on ya. Try disconnecting both wires to pump as you try to shut it off. You probably know, the pump does not have a return spring, so it has to manually go back to idle if the cable is off.
All this has been done with the throttle cable unhooked and moving the throttle lever by hand. Checking fuel return line for any blockage now everyone we have look at it says it seems fuel ralated becouse it doesnt smoke and shuts like a run away on oil does. the Cdr valve is not hooked up and front cover is off the engine so iv taken crank case pressure causing it to push oil or anything like that out of the picture
I haven't tried pulling the wire off when it goes just jump to chocking it out next time i try it i will try puling the wire when it goes and see if that shuts it off. it shuts off fine with the key when idling but no affect when it starts to take off. trying to figure more out before i start it again feel like m pushing my luck on getting it to shut down
