Ignition frustration, losing ground
Now here is the puzzler. The points, condenser, and rotor that were in the distributor don’t match with the spares I have had in the glove box for a couple of years. I ordered them from Dennis Carpenter for a 292, which is what my engine is. Both a local NAPA store and an O’Reillly’s bring out the same parts as my spares when we reference a 292 engine.
We went through several boxes of points until we found a match for my burned set. Same for the rotor and the condenser. The lad at O’Reilly’s back checked the part numbers for the matching parts and he said they would fit a 1967 289 engine.
Here is my question for today: Can a distributor for a 289 be put into a Y-block 292? When I next get to the garage wher my truck is stored, I will stake photos of the dizzy to see if anyone can identify it. I saw a suggestion to look for a tab on the distributor for identification and I will check for that too.
Ross, I believe my bump start switch was (is) ok. The new one worked when I switched to post on the right side of the solenoid. I also swapped the old solenoid for the new one I had. On a closer look, the hot (positive) lead connected on the right side terminal. I think that is reversed to what it should be, but it has worked for three years and the bump start remote switch is working fine now.
Oh, the suggestion to check my battery was good. It is outputting 13+ volts. It took a good charge after the visit to the body shop with my new Optima digital charger. It’s at 100% charge and with conditioning mode.
Thanks again to everyone for the inputs. I think we’ll be back to “running splendidly” tomorrow. I need to get it going as I have sold and closed on the property where I was storing it. Next task will be to find storage for the truck, the MG, and a 4x4 compact tractor.
Good luck with your issue.
B
I don't know when the cable connections changed but my '64 has the main battery and start cables connected "backwards" (compared with later years) to the solenoid and it looks factory because the yellow wiring harness won't reach any other way.
In any case connect one remote starter clamp to the righthand terminal on the solenoid - that's "positive", the cable direct from the battery to be clear. The other clamp to the "I" terminal as in your pic.
The parts store condensers these days have turned out to be problematic in a big way. If you have any junkbox condensers that may be a better choice. For test purposes at least you could try the one that doesn't fit. Nothing says it has to be installed inside the distributor. Extend the lead by soldering a longer wire and shrinkwrap etc. It needs to be grounded to the housing.
Double check the gap on points and make sure the point faces are clean. They can build up a tough skunge that is difficult to remove. Modern manufacture points are crap today too, but they should at least work for a little while. Ignition coils can become defective for certain, but it's not super common. Between the two on hand, should be good to go. Let us know what you find.
I hate to suggest this but a Pertronix Ignitor may be a good plan here. Futzing with breaker points, condensers and worn out distributors is not a good use of our time particlarly.
The heavier yellow wire is on the right side of the solenoid (as you look at it) on my ‘56 (negative “hot” cable from the battery) and I am certain that is the factory figment. I agree, the yellow wires won’t go the other way. - Thanks for your reply.
My 54 has the battery cable (the black one) going to the passenger side post. The blue cable goes to the starter. This is an old picture I have now replaced the cables. The one to the starter is now welding cable. And please disregard the splices on the wires going to the solenoid. I ordered a new stock wiring harness for MidFifty in 1999. It was too short to reach teh solenoid. Only last winter did I figure it out. 1954 trucks had a junction block that the wiring harness went to, then short wires went from there to the solenoid. Ford made a change for 1955. They do not have a junction block. My 54 was made late in the model year. It did not get the junction block.
Edit: Matter of fact upon further study of my pictures of other trucks and remembering what Dennis told me about his 54, the 54 trucks (and 53's) have the solenoid mounted on the frame.
I am going to look for that tag or any other numbers to see if we can identify the distributor. I will take and post photos. I believe, from a cross reference the guys at O’Reilly’s did on the points / rotor that matched what I have, the distributor may be from a late 60s (1967) 289 engine. At least I have part numbers for what appear to be replacementsfor the ignition components that were in my truck. I wouldn’t have thought that a Y-block engine could get a parts transplant from a later V8 block, but I suppose anything is possible.
I may consider for the future installing a Pertronix electronic ignition, but first I want to know that the potential for hotter spark won’t bring the potential for burned pistons or valves. My engine is old, worn and vulnerable.. To protect tappers, I am using Indiana Classic Car Club motor oil which has been formulated for a correct balance of zinc that has been formulated out of modern oils I am also using a lead substitute fuel additive in the hopes of getting better upper cylinder lubrication for longer valve life. I also use non-ethanol fuel and sometimes some Marvel’s Mystery Oil goes in the tank.
Those points do appear to be totally burned up. I'm sure that's your primary problem.
If 1957/ , the points and condenser are still available from FORD/MOTORCRAFT and sources will be SUMMIT or AMAZON. Leave the off-shore junk alone.
Don't worry about an IGNITOR II upgrade. It will not damage the engine. In fact you will be surprised how well it will run.
Two photos- 1st LOM (pre 1957) and the 2nd DUAL ADVANCE (1957- ) -
This is a 12V NEG GRD SYSTEM?
POINTS - B8Q 12171-A (MOTORCRAFT DP-12) and COND C9AZ 12300-A (MOTORCRAFT DC-13A)
If after you get the points changed out and gapped, and if it still does not run, take a 12 volt test light, and wire it across the two coil terminals. As you are bumping the engine over with the bump switch, you should see the light flash indicating you are getting current through the ignition switch and the new points you just installed.( At this point as the engine is cranking and if all is connected at the start relay correctly the ballast resistor is out of the circuit.) If it does not light or flash, then you need to go back and find where you are losing your 12 volts at. Temporarily disconnect the test light lead from the distributor side of the coil and ground the test light to a convenient place on the engine block. With the ignition switch on and not cranking it should light. If it doesn't light then you need to go back and find where you are losing your 12 volts at. Keeping the one side of light grounded, move the other lead of the test light to the ignition switch side of the ballast resistor. If you get light there, you have found a bad ignition resistor or bad connection on the resistor. If it does not light there you may have a bad ignition switch or loss of 12 volts to the ignition switch. My guess would be the ballast resistor would be open since those points got as hot as they were. That ballast resistor is "shorted out" by the "I" terminal of the start relay during cranking, but after the engine starts and you let off the key, the resistor is now back in circuit, and the current for the coil flows through it to keep the engine running.
I hope this helps.
Thanks for letting me share some ideas!
I have new solenoid, coil, breaker points, condenser, and rotor installed. Points age gapped, as best I can see, to .015 with my blade feeler gage tool. Lube applied to the arm that rides on the shaft lobes.
Now to something that will tell someone what is wrong.
Engine fires and revs with throttle if I keep the key turned to engage the starter. On releasing the key to the run position, the engine dies completely with no sputters or coughs at all. I looked at the ignition switch under the dash. It appears to have been replaced at some time and looks newer that the 63 years that the truck is.
So something is killing my spark (or making it too weak) on moving the key from the “start” to the “run” position. Do you suspect a faulty ignition switch or a fault downstream in the wiring, the solenoid, etc.? I am making progress, but need some more pointers.
Again, FTE and especially the ‘48 - ‘56 forum THANK YOU, THANK YOU for your help. I am certain that someone will have insights on what to do next.
Run a temporary jumper from the (+) battery terminal to the coil (+) terminal, see if that fixes it. But don't leave that connected any longer than needed, or run it without the ballast for more than needed.
