Sponsored by: Auxito
2001 door lock cylinders
Old Nov 3, 2018 | 08:44 PM
rickthefix's Avatar
rickthefix
When I bought this truck early summer the key worked fine in both door locks. Now that it's getting colder it is a lot of effort to get them to work properly.
Watched some youtubes and it sounds like one or more of the cylinder pins are too high, guess it has something to do with the temp change and lots of wear on the keys?
Any thoughts or experience on it?
Will be removing the driver cylinder soon to inspect.
Old Nov 4, 2018 | 09:24 AM
alloro's Avatar
alloro
Did you spray some WD-40 into the cylinders yet?
Old Nov 4, 2018 | 02:09 PM
rickthefix's Avatar
rickthefix
No, that stuff is not a lubricant. I used PTFE dry lube spray. It helped a little but still not good.
Old Nov 4, 2018 | 03:08 PM
rickthefix's Avatar
rickthefix
I just ordered a replacement cylinder kit from Amazon for $17 delivered and will replace my worn out cylinder
Genuine Lock Cylinder - Ford 7C3Z-1521990-A
Dean06919
Apr 30, 2016 01:14 PM
AKHunter93
Mar 10, 2016 07:53 PM
TheBigF
1997 - 2003 F150
May 3, 2010 02:15 AM
dustof45
1947 and Older Ford Trucks
Jan 26, 2005 08:32 AM
