Tie rod ends Econoline
Old Nov 3, 2018 | 03:15 PM
tortillasoup's Avatar
tortillasoup
Which direction should the tierod ends be facing? The parts diagram for the e-150-e450 shows the tie rod ends with the castle nut on the top yet I've been looking at some E-350 and the tie rods are facing downward with the castle nuts on the bottom. Yet if I look for pictures online, I see a mixture of the tie rod ends facing upwards and facing downwards. I'm not really sure now which direction they should go. I'm also wondering if it varies depending on if it's an e-150, 250, 350, 450, etc.
Old Nov 3, 2018 | 04:39 PM
jimbbski's Avatar
jimbbski
The stud of the ball joint has a taper to it and the hole in the steering linkage will have a tapered hole to match. They will only go in one way.
Old Nov 3, 2018 | 05:03 PM
98Econoline150's Avatar
98Econoline150
Typically 1992-2006 E150s have the tie rod with the stud up and then 2007-2014 they are studs down like the E250, E350 and E-Super Duty (1992-2014).
Old Nov 5, 2018 | 11:26 AM
tortillasoup
Thank you. That's the answer I was looking for.
Odisvan
25
Oct 15, 2018 04:24 PM
Harrier
121
Mar 27, 2017 04:14 PM
bigcrunch
Apr 11, 2016 10:54 AM
Randyb12
Mar 12, 2004 06:37 PM
