‘66 F100 shifting issues....
Old Nov 2, 2018 | 05:28 PM
‘66 F100 Pearl's Avatar
‘66 F100 Pearl
So on my F100 3 on a Tree, 1st and reverse work fine. But it won’t engage 2nd or 3rd. Nothing’s binding up. However when you manually move the linkages the transmission and shifter move. But when using the shifter it doesn’t...
what could be the problem and the solution. No place I’ve looked has new shifter tubes in stock and many are discontinued. So hopefully it’s something I can fix on my own?
Please help... much abliged
Old Nov 2, 2018 | 06:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are 2 rubber bushings and insulators on the selector levers at the bottom of the steering column.
The bushings harden, crack apart, the shift lever binds up between first and second.
C5TZ-7343-A .. Bushing & Insulator Kit / Obsolete
1965/72 F100/250 with 3 speed M/T
MUSTANG'S ETC in Van Nuys CA has 2 = 818-787-7634.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2,066 = 800-476-9653.
Old Nov 2, 2018 | 06:34 PM
‘66 F100 Pearl
ive got some new bushings but why would that make it work only when moving the linkage. There was so binding.
Any tips on replacing them? Seems fairly straight forward
Old Nov 2, 2018 | 08:04 PM
john jamieson's Avatar
john jamieson
I had a similar problem on my truck. With mine, a PO had used the wrong retainers on the ends that lock the rods to the levers on the side of the transmission. This caused the joint to be loose and move with out changing gears when shifting. Some times I could jamb things up which required getting out of the truck and pulling on one of the shift rods to free things up.
john
Old Nov 2, 2018 | 09:48 PM
‘66 F100 Pearl
FIGURED IT OUT
So the spring inside the steering column was a little too weak and the cone bushing wasn’t seating correctly. So to fix it I happened to have a 1/8” thick washer that was the same size and it fixed it.
Old Nov 4, 2018 | 01:24 PM
‘66 F100 Pearl
I Lied....
it actually didn’t fix it... it helped a tad but not really....
Old Nov 4, 2018 | 01:28 PM
john jamieson
Did you check the other things mentioned? You may want to check the hole in the shift tube that the shift lever goes into. It can crack or get wallowed out causing poor shifting
sonny1965
19
Jul 29, 2021 12:14 PM
Sir Jarrod
Nov 26, 2018 11:14 PM
stp1971
13
Apr 2, 2013 05:25 AM
hoofangler
Jul 7, 2005 09:15 PM
jasonh300
Jun 27, 2003 07:36 AM
