MA November 2018 BS Thread - Give Thanks The White Crap Isn't Here Yet
#527
Good afternoon Jim...Bud...Shaun-ster...it's turned into a bright...cold...windy mid fall day in the Northeast...got some white crap in the forecast for overnight. Just flurries...nothing to worry about. I do however remember shoveling 18" of partly cloudy back in the 80s. Not looking for a repeat!!!
#528
Afternoon Ken-ster. I will be pulling my WHITE GOLD blower out of storage in the next week or two.
#529
Don't know why you'd even have one of those, Shaun. Buying those are an insurance policy that you will never need it !
#530
Mine is still sitting where I parked it last spring...I suppose I should drain the gas tank and run some fresh gas through it. If I can't get it started...I'll call my local Ariens dealer and have them pick it up for a servicing.
#531
I'm fine too Bud...thanks for asking...hope you are as well.
#532
I will service mine once I get it home. Change the oil and plug and I put it away with no fuel in it. So add some ethanol free gas and should fire right up.
#533
I only have mine serviced when I can't get it started. I kept meaning to drain the tank...but...slacking always got in the way and I never found the time to do it.
#534
I give mine a once over and an oil change. I will check the plug and clean and regap it if needed unless it needs replaced. Otherwise a good once over and oil the cables and tighten them as needed.
#535
And...on that note...I think it's time for lunch...gonna heat up the grill and enjoy a cheeseburger. Type at you'se later.
#537
Hey Ken, hope you are surviving OK . Didn't want you to think I'd purposely forget you. I did say Good Morning ! I know you're OK...you just got your oil changed yesterday !
#538
Received 4,200 Likes
on
#540
on
