Installing a block heater
Old Oct 29, 2018 | 02:10 PM
Ritten's Avatar
Ritten
4wd Low
Well, it looks like I'll be relocating up to Anchorage, AK from south Louisiana this coming spring. We really don't have much use for block heaters down here but figure I'll need to put one on my 2017 F250 6.7l. I usually do my own wrench turning but this is something I've never touched before so I'm looking to anyone that may have done it themselves for a guide or tid-bits on this engine. I haven't gone to the dealer to get a quote but I'd rather avoid that if it's easy enough. I searched but most threads concerning heaters had to do with usage rather than install.
Old Oct 29, 2018 | 02:34 PM
seville009's Avatar
seville009
You positive you don’t already have one?
https://www.ford-trucks.com/forums/1...ck-heater.html
if you don’t have the cord, you may have the element slready there, and just need to buy a cord
Old Oct 29, 2018 | 03:35 PM
Gumbeaux's Avatar
Gumbeaux
I'm curious on this as well. On my Cummins, you just had to add the cord. I've done a little research and that doesn't appear to be the case for the Powerstrokes but I can't confirm that.
Old Oct 29, 2018 | 05:41 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
7.3 6.0 & 6.4 all had the heating element already in the block.
IDK bout 6.7
i bought my 6.4 cord from Napa.
Old Oct 29, 2018 | 06:37 PM
wicked 2018's Avatar
wicked 2018
mine was already in the block, just had to add cord.
Old Oct 29, 2018 | 08:12 PM
Boasty's Avatar
Boasty
So if I have the plug on the front bumper I have a block heater correct?
Old Oct 29, 2018 | 08:33 PM
wicked 2018
yes (and 10 letters)
Old Oct 29, 2018 | 08:49 PM
Towerhog's Avatar
Towerhog
If your looking for install tips. Here you go. Don't use his part numbers. Just his procedures. Its a really slick way to do it.
Old Oct 29, 2018 | 09:02 PM
ymsmiley's Avatar
ymsmiley
Gonna have to check mine now
Old Oct 30, 2018 | 03:26 PM
2019er's Avatar
2019er
I saw a video on youtube of a guy starting his diesel at -20f without the block heater. I was wonder about it since I'll be parked somewhere I couldn't plug it in anyway. If someone has had a different experience with cold starting, please chime in. Was wondering how long it would take to warm up the cab without the cab heater as well. Found a few trucks I could live with, but don't have these options on them down south here.
Old Oct 30, 2018 | 04:12 PM
V-22 Osprey's Avatar
V-22 Osprey
I've seen those same videos, coming from a 7.3 with 275K miles thats amazing! I don't know how good or bad it is for the motor, but I'm glad it can do it if needed! That said, I don't plan any YouTube worthy cold starts! My manual says the block heater is recommended at -10F. Seems like I read somewhere about three hours on the plug is good.
Old Oct 30, 2018 | 04:36 PM
wicked 2018
To give more detail, my truck had the $95 option for block heater. I didn't check upon pickup - but when I looked at home there was no plug but the was the block heater installed. I called the dealer and they tried to tell me the $95 option was just the block heater and the plug was "extra" - after a quick back and forth he agreed and they sent me a new Ford plug in the mail.
Old Oct 30, 2018 | 04:40 PM
flanneljunkie's Avatar
flanneljunkie
I'm in Fairbanks, AK and block heaters are pretty much standard equipment up here. Anchorage is hit and miss, with many vehicles not having them installed. While Anchorage can get cold, -20 isn't common. I'd wait until you get up here to determine if you really need to install one (if you don't already have it).
Old Oct 30, 2018 | 06:21 PM
Ritten's Avatar
Ritten
4wd Low
Well, I certainly don't have one. At least not the cord. There's nothing inside the bumper, behind the bumper, under the bumper, or anywhere else that even closely resembles one. It's also not on the window sticker.
Old Oct 30, 2018 | 06:52 PM
wicked 2018
Take a peek at the block just behind the passenger tire - you should see a two prong connector if you ave one.
This video at about 1 min explains/shows the location on the block to check.
