Hood bug deflectors -worth it?
Old Oct 29, 2018 | 12:42 PM
Turbo Dog's Avatar
Turbo Dog
Wondering about adding a hood bug deflector to help eliminate the paint chipping on the front of the hood. Are they worth the cost and do they affect the mpg?
Old Oct 29, 2018 | 12:52 PM
ForeverFixing's Avatar
ForeverFixing
I had one on my last truck. I liked the looks of the dark bug deflector on the white truck but it was hard to clean under it. I came away with the feeling it was just for looks and did not add one to the new truck. I didn't do any on and off to address your fuel usage but I do not think such a small change would make a difference.
Bug screen a 2005 F350
Old Oct 29, 2018 | 12:58 PM
tony m 6.7's Avatar
tony m 6.7
I would say yes they are worth it. They keep rocks and other small debris from hitting the leading edge of the hood.
Old Oct 29, 2018 | 01:50 PM
Poncho450's Avatar
Poncho450
Personally, I don't like mounting brackets, drilling or the gap between hood and deflector, so I use Aeroskins that stick directly to the hood. Never had one come loose yet.
Old Oct 29, 2018 | 02:17 PM
Philisophe's Avatar
Philisophe
FUEL ECONOMY AND PERFORMANCE TIPS
HOW DO BUG DEFLECTORS WORK – ARE THEY WORTH IT?
  • January 12, 2016
It’s hard to believe that a small piece of plastic installed on the leading edge of your vehicle’s hood can deflect bugs. So hard to believe, in fact, that many people wonder if bug deflectors work as promised, eg. do they actually keep bugs from splattering on the windshield?
The short answer? Maybe. Depends on the bug deflector. Here’s what you need to know.
WHAT ARE TRUCK BUG DEFLECTORS SUPPOSED TO DO?
There are two main missions for a bug shield:
  1. Redirect air flow around your truck so that fewer flying bugs splat on your windshield.
  2. Absorb impacts with bugs (and perhaps some other “stuff” that might hit your front window, like rocks) so that the window glass doesn’t have to.
HOW WELL DO TRUCK BUG DEFLECTORS DO WHAT THEY’RE SUPPOSED TO?
https://www.flickr.com/photos/9597476@N07/3579361216/
This is what causes the most debate: There isn’t a preponderance of evidence for or against. Some people swear that bug deflectors work, others say no way.
Part of the problem might be that bug deflectors aren’t all the same. Some deflectors are wind tunnel tested and carefully designed to alter airflow, while others are just someone’s “best guess” as to what the deflector’s shape and position should be.
Unfortunately, the aerodynamics of bug deflector design are complex. You can’t just mount a basic air dam to the front of your truck’s hood and magically reduce bug impacts. This is because:
  1. The airflow over the front end of each vehicle is slightly different. GM, Ford, Toyota, etc. – they all have a slightly different front end design, and therefore different aerodynamic factors at play. A “one size fits all” truck bug shield probably won’t work.
  2. The angle of the deflector matters…a LOT. The single most important factor in bug deflector design is the angle. If the angle is too steep (meaning the deflector is perpendicular to the hood), it can’t sufficiently alter airflow to reduce impacts. If it’s too shallow (meaning it basically lays down on the contour of the hood), the impact on airflow is minor.
There are no hard and fast rules in bug deflector design. You need to model the airflow using computational fluid dynamics software, then test in a wind tunnel. There are no shortcuts, and there’s nothing cheap about this process.
Therefore, consumers should only purchase bug deflectors that have been wind tunnel tested.
DO BUG DEFLECTORS REDUCE GAS MILEAGE?
In a word, yes. But the reduction likely isn’t huge. Canada’s National Research Council (along with Clarkson University) studied the effects of bug deflectors on commercial trucks to see how they impacted fuel economy. The long and short of it is is that bug deflectors likely reduce fuel economy 1-3%, and really only at highway speeds.
If we assume the worst – that bug deflectors reduce fuel economy by 3% – then a good way to estimate the impact on your fuel bill is to increase the amount you pay for a tank of gas or diesel by 3%. If you’re driving a big 3/4 or 1-ton truck with a 30 gallon gas tank, then you’re looking at buying an extra gallon of gas every time you fill up. For most people, this won’t add up to more than $100 a year (and for many it will be quite a bit less).
Still, bug deflectors aren’t necessarily “cheap”, as they’ll cost you money every time you fill up.
WHAT ABOUT PROTECTION FROM ROCKS AND SAND?
If we’re talking about small rocks and sand or grit, a properly designed bug deflector (meaning one that’s been wind tunnel tested) can probably help to reduce damage to the front window glass. These objects are small enough to be “carried” by the air flowing around your truck at speed.
However, no amount of airflow manipulation is going to “carry” a sufficiently large rock away from your windshield. Once rocks become big enough, gravity wins and the trajectory of the rock is all that matters…if it’s headed for your windshield, it’s not going to be stopped by a bug deflector.
So basically, bug deflectors may prevent damage from small rocks and sand (window pitting) but won’t do much (if anything) to prevent impacts that lead to chips or cracks.
NOTE: If you’re trying to prevent damage to the leading edge of your hood, consider “clear bra” material from 3M. It’s UV protected, clear, and absorbs impacts, preventing paint damage to whatever surface it protects. The material can be applied to any painted or plastic surface (like your vehicle’s front valance, or the back of side mirrors, etc.).
ARE BUG DEFLECTORS WORTH BUYING?
Only you can decide the answer, but the questions we’d suggest asking are:
  1. Are you dealing with a lot of bug impacts, and if so, have you looked into wiper blade upgrades? Upgrading your vehicle’s window wiper blades (or replacing them regularly) can go a long way towards keeping window glass clean.
  2. Are you willing to pay both up-front and every time you fill up for a cleaner windshield? If you’re OK with dropping $100+ on a bug deflector, plus another few dollars every week or two in additional fuel, than by all means go for it.
  3. Are you looking for some style? We didn’t talk about it much, but bug deflectors often give a vehicle some style, and that’s a perfectly legitimate reason to add a bugshield to your vehicle.
Old Oct 29, 2018 | 02:31 PM
PentaPop's Avatar
PentaPop
Maybe a bug deflector would stop that annoying splatter of rain water from flying out of the recesses in the hood whenever I pull up to a stop sign! I’m about to the point where I just want to drill a drain hole on each side and be done with It!
Old Oct 29, 2018 | 04:52 PM
Turbo Dog's Avatar
Turbo Dog
Seems they aren't worth their money since they will cost fuel mileage to drop. I don't think I can do the 3M clear bra thing to the front of the hood because of the Super Duty logo.
Old Oct 29, 2018 | 07:02 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I drilled a 1/4" hole on the drivers side and it helps, I use the 3-m clear guard, they went around the wording and installed the chrome letters. I did install a bug deflector on my 2016 F150, because the rain/slush would follow the hood line up to the windshield!
Old Oct 29, 2018 | 07:19 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
AVS Aeroskin 2....fits flush like a bra and protects from rock chips and bugs on the hood. Raised part in the center deflects some bugs off windshield but not all. No turbulence at base of windshield like some others I had caused.
Old Oct 29, 2018 | 08:41 PM
super 6.8's Avatar
super 6.8
I've always had one just to prevent chips on the leading edge of the hood. It will do that job very well.
Old Oct 29, 2018 | 09:17 PM
burgy's Avatar
burgy
I have the Ford one with the SUPERDUTY embossed in it. Like the look and mounts flush.
Old Oct 30, 2018 | 05:28 AM
SCOTTx88's Avatar
SCOTTx88
Old Oct 30, 2018 | 08:02 AM
Bee-Man's Avatar
Bee-Man
Originally Posted by Turbo Dog
Wondering about adding a hood bug deflector to help eliminate the paint chipping on the front of the hood...
I'm not one who changes vehicles often, and after taking the pictures to list my 08 Tahoe for sale and seeing the 23 chips that showed in the pics, a bug deflector was the first thing I ordered when I picked up my truck last month. That leading edge takes a beating over time, why not protect it?
Old Oct 30, 2018 | 08:25 AM
Flyct's Avatar
Flyct
FTE Community Team
The Ford OEM Hood Bug deflector absolutely keeps bugs off the hood and prevents sand etc from chipping the hood. It does only slightly reduce bug splatter on windshields.
The Chrome one cleans up easily even and doesn’t scratch.
Here is is an example of nasty bug splatter. While the front of the truck and the bug deflector was splattered there was not one bug was on the hood. I use an Aero Bug Scrubber to remove bug splatter. It does a great job on removing bug splatter from windshield also.
https://www.amazon.com/gp/product/B00NFWUS8O/ https://www.amazon.com/gp/product/B00NFWUS8O/
Plus I like how the chrome seems to finish the chrome look on the front end of the truck.
Old Oct 30, 2018 | 08:45 AM
Turbo Dog's Avatar
Turbo Dog
I also have the chrome package so I'll go with the chrome Ford one. The rock chips are what I mainly want to prevent. Thanks for all the input!
