2001 B4000
Old Oct 26, 2018 | 03:47 PM
Whitney49's Avatar
Whitney49
2001 B4000
When setting on a level spot I've noticed that the rear of the truck sits lower than the front...leaf springs go weak on these.?? .have factory lift kit if that makes a difference..was thinking overload shocks...thanks in advance...
Old Oct 26, 2018 | 05:48 PM
pawpaw's Avatar
pawpaw
Has it ever been seriously Over Loaded???
Shocks aren't supposed to provide Lift, just dampen movement. Consider having a known good/trusted suspension shop have a look & quote what needs to be done to make its ride height right & safe.
Old Oct 26, 2018 | 08:22 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Sounds like your springs are worn out. If you go with new replacement ones it should bring that rear up back to factory. If you go with a heavier duty set it will firm up the ride a little and also give you some additional height over factory.
Pretty normal for springs to get tired and fatigued.
Old Oct 26, 2018 | 09:00 PM
Whitney49's Avatar
Whitney49
Kind of figured the springs were shot.. thanks for the replies
Old Nov 12, 2018 | 12:38 PM
Whitney49's Avatar
Whitney49
Follow up
Well..the truck is in the shop..getting rebuilt with new perches..shackles..and springs rebuilt..all new bushings as well..a common problem according to the shop..
Old Nov 12, 2018 | 03:12 PM
pawpaw's Avatar
pawpaw
Ok, was the frame ok, did they find any signs its been seriously overloaded in the past? Being in cold country with salted winter roads, if its been driven much in the winter that danged salt sure can take its toll!!!
Old Nov 12, 2018 | 05:01 PM
Whitney49's Avatar
Whitney49
Frame is okay...been a farm truck until I got it...seldom on road..rusty yes..overloaded.? Good question..quite possible..everything looked good underneath 3 years ago...put newer motor in then..suprised both sides went at same time..I've not overloaded truck since I've owned it....
Old Nov 13, 2018 | 10:05 AM
pawpaw's Avatar
pawpaw
OK, good feedback & to hear it sounds like its frame is ok & the suspension can be resurrected, let us know how it goes. Having been a Farm truck, no telling what & how much it had been tasked with hauling before you came by it.
Old Nov 13, 2018 | 01:28 PM
Whitney49's Avatar
Whitney49
From all the issues I've dealt with..mechanical and electrical..I would say that if the key fit and it started it.was good enough...I've got a 04 Explorer motor in it with around 50k on it..truck is showing 118k...the abs is messed up...door ajar light comes on and off when hitting bumps in the road..have read many posts on these problems... and slowly sorting them out...when I get done..should have a good reliable truck..
Seabee Mike
Oct 23, 2017 09:28 PM
fjatheart
Jul 22, 2010 11:10 PM
1985 Ford F-150
Offroad & 4x4
17
Sep 22, 2008 09:58 AM
bigsub
Jul 19, 2005 01:46 PM
mizzitch
Mar 5, 2005 06:55 PM
