Towing at night, getting high beamed flashed.
So I had to tow through the night on my last trip, something I try to avoid, but was unavoidable this time. I kept getting flashed by on coming drivers because apparently my lights are too high and blinding people. I have 2016 F250 with the camper package and use an 4 Point Equi-li-zer Hitch. The tongue weight of the trailer is only 700 lbs and the hitch is adjusted correctly according to the owners manual height measurements. The truck rear end drops approx. 1 1/4 from unloaded height, but this is enough to throw the alignment off for the lights. I am looking for suggestions on how to remedy this issue without using the hitch to do it. Using the hitch would put the adjustment out of the normal range according to Equi-li-zer. basically the truck sags too much even with the hitch attached. I have looked into the Torklift spring helpers, and they look reasonable. Is there other possible solutions? PS I do not want air bags, I think that would be over kill.
My first question would be, are you sure the tongue weight is 700 lbs? Are you guessing or have you gone across the scale.....like a CAT scale at most truck stops? If in fact your tongue weight is only 700 lbs, are you carrying anything else in the bed of the truck that would affect the rear to sag? When I had my 2011 F250 CrewCab 4x4 Diesel (no camper package on it), just towing a 7' x 16' enclosed trailer that weighed in at about 5K lbs, would cause the rear end to sag a bit. I ended up putting air bags on the truck, as I spent quite a bit of time driving home from the track on Sunday evenings in the dark. One of the things I would highly recommend though is to load the truck and trailer up exactly like you use it/tow it, and go across a CAT certified scale for more precise numbers.....if you haven't already done this.
I'm not sure why you would be against the use of airbags to level the truck. Airbags provide a very good method for levelling the truck. Keep in mind though, they do NOT add any additional payload capacity to your truck. Their purpose is to level and stabilize.
I tried that several times with a few angry responses. So it must be a substantial problem for them. I never had this issue with my F150 and the same trailer. The camper package makes my truck sit almost perfectly level unloaded so any squat throws the lights off. I just was trying to avoid the expense of airbags, I had them on a prior truck. Can these lights be adjusted like on the older models?
Received 6,693 Likes
on
1. Do you have a leveling kit installed on the front? If so, there's your problem. Even without the trailer your lights are probably not aimed right.
2. What is the measurement of the front wheel well height before/after the WDH is connected? If you aren't getting the front close to the unloaded height then you probably don't have the WDH configured right.
Headlight misadjustment is an extremely common issue with loaded pickups especially lifted or trucks with leveling kits. Additionally when you have the fog/driving lights on they are really bad even when not loaded.
There are recommended methods to adjust head lights so when you are ready to tow. The other is and this is for anyone driving in traffic, turn off the fog/driving lights. They are set just way too high and areareal aggravation. I got ticketed by both Oregon and Washington Howayda patrols for this one when I was headed home.
And yes, turn off your G%&@#$ fog lights.
Now let’s be calm about this. Many people don’t understand the importance of properly adjusted lights to overall safety on the highway.
used to be we had vehicle safety inspections where they checked the vehicle and there were less issues. Now they never check height let alone the adjustments.
An event that happens on nearly every roadway, every night. The driver of a vehicle sees an oncoming vehicle with brighter lights than expected. Driver of the first vehicle flashes their high beams once or twice to remind oncoming driver to dim their high beams. Driver of oncoming car responds with a single flash of their high beams, to demonstration, that their high beams were in fact not on. Nobody is hitting the breaks, making a U turn, running anyone down, then what, forcing them off the road, before retrieving a sledgehammer to smash headlights. (I guess if you ever do find yourself in this situation, you would be pretty well justified to use 8000 pounds of truck to remove yourself from the situation by driving over them while they are on the back swing with the hammer)
