Get the toughest hitch for all your towing needs!
The SuperHitch Outlaw Series is the toughest hitch around. Capable of towing 3,000 pound tongue weight and a 30,000 pound load with weight distribution, this hitch will get the job done. Its reinforced hitch pins, dual receivers and high impact powder coat increase the longevity of the hitch.
Trucks are getting more heavy duty and are manufacturers are coming out with 21,000 pound tow rated hitches. Torklift saw the need to tow and haul heavier trailers and items, so decided to manufacture heavy-duty tow hitches to meet everyone's needs - in comes the SuperHitch Magnum. The high tongue weight capacities are critical to ensure that your customers are safely towing their loads. Often times trailer manufactures design trailer axle placement set back toward the rear of the trailer due to the trailers intended use.
On trailers such as toy haulers, equipment trailers, horse trailers, car trailers, enclosed trailers etc. a major amount of weight is common due to the manufacturers rearward axle location.
On these types of trailers, the vertical load (commonly referred to as tongue weight) rests at the front of the trailer resulting in significant strain on the tow vehicle hitch equipment. If the trailer hitch system tongue weight rating is not at least marginally higher than the trailer's actual measured tongue weight (when the trailer is loaded) catastrophic hitch failure can occur. Trailer hitch towing system failure from inadequate towing system tongue weight ratings is the most common cause of accidents related to trailer hitch failure. The SuperHitch Series is the only hitch line in the industry with hardened reinforced hitch pin locations. The reinforcement prevents what is elongation wear commonly known as "egging" at the site. Once the hitch pin locations egg out, the hitch is damaged and may need to be replaced. Your customers don't have to worry about this with the SuperHitch® line.
The SuperHitch Magnum, our highest rated hitch!
The dual receiver system allows for added strength and use of a high capacity receiver hitch extension if needed along with the allowance of accessories to be inserted into the top receiver. The SuperHitch line is vehicle specific with most applications being no-drill. The SuperHitch Towing Series includes the SuperTruss Extension, Everest Weight Distribution System and ball mount accessories. This American-made product is also backed by the Torklift International Legendary Lifetime Warranty.
If you’re interested in purchasing our SuperHitch trailer hitch and want to upgrade, there are a couple of options available to you! You can click here to visit one of our Certified Dealers near you. You can also contact us for more information or questions at support@torklift.com or by calling 800-246-8132.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
03-21-2018 11:05 AM
Torklift Sheryl
09-28-2017 07:06 PM
Torklift Sheryl
06-08-2017 06:32 PM
Torklift Sheryl
03-23-2017 05:54 PM
Torklift Sheryl
02-17-2017 01:08 PM
