stuck on defrost
Old Sep 25, 2003 | 06:56 PM
MrV300xlt's Avatar
MrV300xlt
stuck on defrost
My truck is now stuck on defrost no matter what the lever is on, i took apart the dash enough to lookl in and everything is hooked up, the lever seems to go into a black box and i guess that makes it change from vent to defrost and everything else but i dont know what to do to fix it, as far as i can tell everything is working right, is that black thing electrical? maybe its shorted out? i really have no idea how to fix it so anyone take a shot
Old Sep 25, 2003 | 07:55 PM
95BlackF150's Avatar
95BlackF150
my wifes car had a broken vacum line that caused hers to do same thing but usually only when pulling a hill or if you hammered on it.
Old Sep 26, 2003 | 11:14 AM
tsheriff's Avatar
tsheriff
My truck was doing the same thing when i bought it.. The previous owner just unhooked the acuator rod under the dash because it was stuck on defrost. Check the red vacuum line behind and alongside the pass valve cover. mine was broke right where it tees off to the top of the heater box.
