Update: So I finally talked with my local inspector. In order to pass inspection, I need to have whatever emissions parts installed that where originally installed for that year. They do a visual inspection only...no sniff tests, in my area. But, I can move that catalytic converters back, as long as they are still installed in the right order.
So, I can use long tube headers, but I have to keep the smog pump thermactor system installed.
Can anyone recommend a good long tube header with the EGR port already installed? I suppose I will need to get the GT40 heads drilled for the smog ports to make that work.
