Electrical issues
Also note, the Gauges in your dash rely on Resistance to work properly. They are not a Voltage based system like your Cruise Control or the lights on your truck. This means the two systems, even if directly connected would and should just short. There is not Computer per say on that truck at all. The wiring for the starting sequence goes as follows. Key turns switch, switch sends power through the resister wire to the Fuel shutoff switch and glow plug controller to determine if glow plugs are needed. Then if you turn to Start, which throws the Ignition switch (at the base of the steering column) then power is sent to the Neutral Safety Switch which allows or does not allow starting based on the position of the center shaft in relation to the pins inside. (is it in Neutral or Park) This is a common failure point, they are cheap now and made of weak plastics. If a manual then there is a similar device that works of if the Clutch is engaged or disengaged. Then the power makes is last leap, where it has to trip the Solenoid on the Fender. This either gets enough Voltage to trip and send the power to the Starter, or it does not. This is another common failure area, but ultimately that is the last leap in power. At that point power is going to the ONLY TWO locations that are technically needed for that truck to start. Fuel Shut Off Switch and Starter. Nothing else is required, even in cold temperatures you can start without Glow Plugs, so the dead circuit in my opinion has to be in the ignition switch area. The Gauges are again on a separate system, so they shouldn't (With electronics... anything is possible) interact at all. If they did it should have nuked your dash.
I've got 2 86's but when they haven't started in the past it's turned out to be a slough of problems.
Main thing I've learned is to have 2 badass batteries to start these old beasts and I've gotta charge my batteries about once every 2 months on the 4x2 but my 6x6 has a short somewhere so I take battery cables off batteries every time i park it. Got to where i let hood click into first latch but wouldn't shut it all the way due to frequently opening to connect & disconnecting batteries. Hood hasn't flown off at 80mph yet haha
Last edited by Onemoreblessedtexan; Oct 22, 2018 at 08:43 AM. Reason: Stupid auto correct
