Sponsored by: Kumho
Tire size question
Old Sep 25, 2003 | 03:55 PM
fordpwr_1's Avatar
fordpwr_1
Tire size question
Ok, just got my Eagle Alloys 058's 16x8 for my '91 F250 4x4 HD and I want to know how big of a tire I can go with no lift. I was thinking maybe 285/75R16, but I'd like some input from someone whose got a similar setup. Any tire suggestions would be appreciated also, I want a more aggressive tread since it's not a daily driver. Thanks.
Old Sep 25, 2003 | 07:32 PM
88B_RONC's Avatar
88B_RONC
285/75R16s will work good on your truck...especially on the 8in rim. I had those tires on the stock rims of my F350 and it squeezed the tires a bit more than I like them to.
Old Sep 25, 2003 | 08:17 PM
RawPower's Avatar
RawPower
8" wide? daaaang. Thats skinny. If you want an offroader, you need to go to at least 12.50's, but I recomend 14's.
As for the largest tire size (diameter) do you have a front end bumper replacement? If you do, then you can easily get 38x12.50R16s. But if you have the factory front end bumper, then you can get 35x12.50R16s.
Old Sep 26, 2003 | 07:18 AM
fordpwr_1's Avatar
fordpwr_1
8" wide
Rawpower, the rim is 8 inches wide not the tire, 285/75R16 works out to almost 33" tall 11.50" wide.
Old Sep 26, 2003 | 08:56 AM
97HD4X4's Avatar
97HD4X4
no F'n way
Old Sep 26, 2003 | 10:30 AM
88B_RONC's Avatar
88B_RONC
Originally posted by 97HD4X4
no F'n way
my thoughts exactly
