Batteries Plus X2?
Old Oct 16, 2018 | 05:47 PM
akblackfoot's Avatar
akblackfoot
[QUOTE=diesel_dan;18253473 charger/maintainer to match...
Scott[/QUOTE]
Recommendations? It's a daily driver so do I need to put a charger/maintainer on it?
Old Oct 16, 2018 | 05:50 PM
Per4mance's Avatar
Per4mance
ImI running the Advanced Auto ones in my Blue truck. They where a up grade over the gold cause I had so many problems with them. There AGM have been great. Eve after the truck sat for 2 months not running and the phone chargers plugged in, they only took a half hour to shut the auto charger off. They always continue to test excellent too. If you want AGM batteries I would def recommend them.
Old Oct 16, 2018 | 06:41 PM
markw365's Avatar
markw365
I'm running the Northstar AGM's in mine. They can be found for 250 give or take 20 bucks or so. That X2 looks suspiciously like the NSB-65. Specs out the same.
Old Oct 16, 2018 | 07:32 PM
diesel_dan's Avatar
diesel_dan
I'm using a CTEK 4.3 on the truck, and I also bought an Odyssey Extreme for my TJ Rubicon so use it for that as well. Even tying it to a pair of those batts, it doesn't take all that long to go into Float mode...
IMHO, it would be plenty for your DD, when you might not drive it for a bit....
Scott
Old Oct 16, 2018 | 09:48 PM
akblackfoot
I found an old thread that somebody claimed to have it confirmed by Northstar employees that they are the same.
Old Oct 16, 2018 | 10:04 PM
akblackfoot
Scott
So you have this installed full time on one battery and plug it in when parked?
Old Oct 16, 2018 | 11:14 PM
diesel_dan's Avatar
diesel_dan
Nope, I have a plug on the TJ, but I use standard clamps on the truck, and as Y2K joked (but I take it seriously) I switch from one batt to the other as to which is closer to the charger....
Old Oct 16, 2018 | 11:54 PM
akblackfoot
Does it come back on in the same mode each time after you select it, or do you need to select the mode each time it's plugged in? I have a setup already that I could tie it into a plug that I already use for my battery pad heaters so it could be a semi permanent install. Just wouldn't want to do that if I have to pop the hood and select the mode each time anyway. Also, if I run this, would the battery pad heaters even be helpful in extreme cold?
Old Oct 17, 2018 | 12:13 AM
TooManyToys.'s Avatar
TooManyToys.
Yes, because no matter what, battery temperature effects current capacity and flow.
Old Oct 17, 2018 | 11:09 AM
diesel_dan's Avatar
diesel_dan
Yes it comes up in the mode last selected. CTEK has their "own" plug end, so since I have a number of vehicles with standard SAE 2 pin plugs, I just bought the converter that one end is the CTEK style plug and the other is standard 2 pin (I had to do the same thing for my Noco Genius charger too, and it has yet another type of plug end).
It sounds like you'd mount the CTEK on the truck then? Not sure how weather proof this unit is... Jack answered your battery heater Q...
Scott
Old Oct 17, 2018 | 03:19 PM
Excurvelle's Avatar
Excurvelle
There is also a thread about Caterpillar AGMs. I would guess most if not all are made by the same manufacturer and rebranded.
Old Oct 17, 2018 | 03:32 PM
akblackfoot
Scott
It says splash and dust proof? I'll mount it near the firewall on the drivers side. Shouldn't be exposed to too much, except maybe cold.
Old Oct 17, 2018 | 04:00 PM
  #28
diesel_dan's Avatar
diesel_dan
You should be good there. Let us all know what you end up getting, price, where bought, etc. (because we're nosey), battery-wise, ok?
Best of luck,
Scott
Old Oct 17, 2018 | 04:28 PM
  #29
akblackfoot
I got them at Batteries Plus. 10% discount for online order and in store pickup. I looked at the Odyssey but they were significantly higher up here and the 5 year warranty is nice on these. Never thought I'd spend this much on batteries but after paying attention to them and having the second set of Interstates from Costco not make it 2 years, I'm just going for it. I have the cable upgrades on my rig and 200amp alternator also.
Old Oct 17, 2018 | 04:45 PM
  #30
04badford's Avatar
04badford
Well , if it were me , I’d get the Interstates from Costco , every four years you take them in for brand new ones , my truck can’t be down for a minute , if something does go south Costco is close , instead of waiting for Internet Warrantee .we also have a Ag supply that sells Interstate and both places are well stocked.
edit just noticed you already did the Costco batts , don’t know why , I’ve had good results from Interstate but not the Costco Kirkland brand they use to leak
