Knock out poor handling effects while towing!
The StableLoad suspension upgrade is meant to assist your truck with heavy loads. Installed on your truck’s rear overload suspension, it dramatically improves vehicle handling characteristics by "pre-activating" the stabilizing effect and keeping the springs actively under load.
Instead of upgrading with multiple products that handle individual problems, address all issues with one upgrade: the StableLoad suspension stabilizer!
"I gained a total of 2 1/2-inches in height with installing the lower and upper StableLoads and the sway is noticeably a lot less. I no longer am thinking about getting airbags, with both StableLoads installed I gained back most of the sag in the rear."
-Kevin ***
The lower StableLoad also addresses these issues, but can turn on/off, returning your vehicle to smooth factory ride when not towing or hauling. With both upper and lower StableLoads combined it resolves all the issues that you would encounter when needing a suspension upgrade. The Torklift StableLoad comes in two application styles. The lower quick-disconnect StableLoad and the upper StableLoad. Alone, the upper overload does a good job fixing these issues.
StableLoads were designed to improve your overall towing or hauling experience. Not only do they improve your experience, but they also improve your safety on the road. Make sure you don’t put yourself, the cargo, or others on the road in danger with delayed stopping, compromised handling, excessive sway or other problems that StableLoads can fix. Rather than spending thousands of dollars on a different solution to each problem, let the StableLoad handle this problem with one simple-to-install application.
Features of the StableLoad include:
-Kevin ***
- Dramatically improves safety, handling, body roll and porpoising while towing and hauling
- Ability to turn on and off in seconds*
- Universal fit for all vehicles with factory installed upper or lower overloads
- Quad contact design complements the vehicle’s specially engineered suspension that automotive manufacturers have invested millions of dollars designing, while all other rear suspension products reduce contact to only two points
- Quick no-drill installation**
- Enhances airbag performance by lowering airbag overload air pressure and activating the factory overloads
- Kit includes four StableLoads (outfits one complete vehicle)
- Legendary Lifetime Warranty includes coverage for the vehicle factory leaf springs
- Proudly made in the USA
* Applies only to the StableLoad Quick Disconnect (Lower Overload).
** Does not apply to the StableLoad Quick Disconnect (Lower Overload) A7311 (with Drill Kit).
Avoid sway, sag and poor handling by installing Torklift StableLoads on your vehicle. Visit our Where to Buy page to find a certified or authorized dealer near you!
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-05-2018 03:07 PM
Torklift Sheryl
09-21-2017 07:20 PM
Torklift Sheryl
02-21-2017 06:51 PM
Torklift Sheryl
01-24-2017 01:59 PM
Torklift Sheryl
01-03-2017 07:14 PM
