Leveling kit
Old Oct 17, 2018 | 07:36 PM
Buxten's Avatar
Buxten
Hey alabamatanker do you have a picture of your truck on level ground vs. the driveway? Also, what type of wheels/ tires are you running? Thanks!
Old Oct 17, 2018 | 09:16 PM
TXSD6.2's Avatar
TXSD6.2
Your truck looks beastly, K-tung. Do you have an issue with bump steer after the 3.5" level?
Old Oct 18, 2018 | 05:55 PM
K-tung's Avatar
K-tung
Thanks TXSD6.2. Yeah I’ve had some degree of bump steer before and after the level, even with the fox stabilizer. It’s not as bad now or maybe I’m just use to it.
Old Oct 18, 2018 | 05:57 PM
benhoopes's Avatar
benhoopes
I wonder if your kit had some caster shims to help with that bump steer. If not I am sure you can add a set to any kit.
Old Oct 18, 2018 | 07:54 PM
TXSD6.2's Avatar
TXSD6.2
His kit (ReadyLift 3.5") comes with radius arm drop brackets, which are supposed to address the issue. I read a thread from someone that added caster cams w/ a radius arm lift the other day and they said their truck with 5+ * of positive caster drove great.
Old Oct 18, 2018 | 11:59 PM
benhoopes's Avatar
benhoopes
3.5” ReadyLift. I like it so far considering the price.
This has got to be the best looking SD I have seen on here. I love it.
Old Oct 19, 2018 | 09:31 PM
K-tung's Avatar
K-tung
I’ve thought about giving the shims a try. I’ve also been considering upgrading to a better setup and maybe going up to the 4.5 range and smaller rims.
Thanks Benhoopes!
Old Oct 20, 2018 | 10:53 AM
FlyinAg's Avatar
FlyinAg
Great lookin' truck indeed!
Old Oct 24, 2018 | 09:32 AM
ChainsandBalls's Avatar
ChainsandBalls
BDS 2". Still gives a bit of rake at 1.5" higer in rear. I didn't want a completely level truck. Nice kit, especially with the new trac bar mount and Fox shocks. Will need a wheel alignment as the factory ball joint alignment cames were not equal and the supplied cams are. If running 37s with a negative offset wheel, you are probably going to rub and will have to trim a lot.
Old Mar 28, 2019 | 02:59 PM
NL_F250's Avatar
NL_F250
ChainsandBalls, what size tires and wheel setup do you have on there?
Old Mar 28, 2019 | 04:00 PM
ChainsandBalls
22x10.5 wheels, 37x12.5 tires Toyo Open Country RT
Old Mar 28, 2019 | 04:14 PM
NL_F250's Avatar
NL_F250
What offset? I have 35x12.5 on 20x9 +18 but haven't had them on the truck yet. Wondering if I could bump up to 37 when I do the level.
Old Mar 28, 2019 | 05:13 PM
  #28
ChainsandBalls
mine are -25 offset. So yes, you could go to a 37x12.5 and probably have no rub with your offset.
KingofBolivar
Dec 23, 2017 09:31 PM
99stroker_
Feb 28, 2017 12:18 PM
BioHazrdMan
May 27, 2009 05:38 PM
