Warped intake valve
Old Oct 15, 2018 | 05:54 PM
redrivergorge's Avatar
redrivergorge
Warped intake valve
Bought a 2001 f150 with the 4.2 and a miss. Turns out after doing a compression test #2 cylinder is dead all the others are at 180 psi. So I tore the passenger side head off and found the intake valve in the #2 cylinder is warped and not sealing against the head. Everything else seems good valve seat doesn't appear to be cracked, checked head with a straight edge looks fine, cylinder is nice and smooth. So hoping to keep things cheap and just throw a new intake valve in it and put everything back together. I know its an aluminum head and I should have it machined just hoping to get away with it, terrible idea?
Anyone know anything about the headgasket kits on amazon? The felpro kits I found are all $250 amazon has some random brands for $100. This trucks just going to be a beater and has other issues so just trying to get the motor running and hoping for the best. Its going to need an upper intake and crossing my fingers the passenger side cat isn't plugged, pretty sure the previous owner drove it this way for awhile.
Also whats up with the throttle plates in the intake? Never seen that system before with the two intake ports per cylinder and the throttle plates in half of them. One of the actuators on the back of the motor for it is broke so gotta get that fixed too.
Old Jan 2, 2019 | 12:11 PM
redrivergorge
Finally getting ready to put this thing back together. Ended up finding an affordable victor reinz head gasket set.
I figured out what the goofy intake port throttle plate system is. Its called an Intake Manifold Runner Control (IMRC). I haven't figured out how to get the clips for the actuators. Heres the kicker, I picked up a haynes manual for the thing and was looking in it to get exact names for the parts of this system. Well its showing the IMRC system for 05 and older 4.2s and showing a CMCV system for 06 and newer. Crazy part is the parts on my 01 are the CMCV system. So now I'm wondering if my haynes manual sucks that bad or if my intake/motor got swapped at some point. I pulled up rock auto and searched for CMCV system parts under an 01 nothing but IMRC parts do show up for it. Just so happens CMCV doesn't show up on an 06 though. So I'm confused.
The other thing is I haven't found the lower part of the upper intake manifold. At least all the pictures every I look only shows the upper half. So not sure what to do there either, thinking I might be stuck with the junk yard for both my problems.
tomkat22
1983 - 2012 Ranger & B-Series
Nov 6, 2018 10:22 AM
righton780
1997 - 2003 F150
Feb 4, 2014 08:02 PM
Fastlane50
17
Nov 12, 2010 08:26 AM
79f100six
Oct 24, 2007 02:25 AM
dinosaurfan
16
Sep 20, 2005 08:37 AM
