Aftermarket power liftgate
I have done searching but have not found anything on the market. Does anyone make an aftermarket power liftgate conversion kit for the excursions? If not are there recommended lifts support struts that make the liftgate easier to open. My wife had a difficult time opening it. It has no issues staying open but requires a lot of force to begin to open. Feels like your going to break the handle off.
Thanks in advance,
Eric
Thanks in advance,
Eric
Mine acts the same way, most likely because the gas struts are near fully compressed, and in-line with the gate/body angle, at that point you really are lifting the gate and it's near full weight till the gas struts kick in. Sounds like you need to fashion a conical spring or 2, like used under the hood to get you started those first few inches. There may be plenty of clearance between body and gate on the left and right for the spring to compress.
Maybe enough demand and these people will add the X to the list.
http://www.che1.com/product/tl105-el...assist-system/
RV_Tech
Fifth Wheel & Gooseneck RV Towing
23
08-29-2016 08:31 PM
rebar13
13
10-10-2014 11:03 AM
montana_highboy
02-09-2012 07:00 PM
E30tdf
17
07-21-2011 10:37 AM
blakeusa
11-30-2007 11:53 AM
