Oil change cost
I can get "The Works" done at my dealer for $110. Which is normal oil change and tire rotation. Synthetic is extra. But not a $220 extra.
Also every 5th oil change is free.
I still do all my own during reasonable weather. I'm not going to crawl under my truck in a driveway filled with icy slush. And I don't change the oil in my garage, I've had too many spills to gamble on a mess on my garage floor
Go to Wal Mart with your oil and filter. They charge about $20 for the labor after credits for the oil and filter on their standard oil change. Total cost would be less than $100 with you buying full synthetic oil and Motorcraft filter. Even less if there are rebates on your brand of oil.
Would suggest that if you plan on supplying the oil regardless of the facility you plan on using, you take the exact amount needed. You would need to get a one quart oil bottle and fill it with your choice for oil. Then you can carry it with 3 one gallon containers of your brand of oil.
$330 does seem a bit high. Did they tell you what they are doing? What are they considering "the works"? Have you received the DEF 500 or 200 mile warning? If they are doing 2 jugs of DEF, Synthetic Oil change, Fuel Filters, Air Filter, Rotating the Tires and I would imagine all other fluid checks it's probably close to $330.
