Replacing my clutch/brake pedal assembly bracket , got the permanant fix piece for my slave clyinder push rod . Excellent pedal bracket but the fire wall still needs fixed . It flexes by the slave clyinder . Gotta do it all this problem is a nightmare ..lol
I did this procedure on my 88. Took some time for sure.
pulled everything out That was in the way. Pain in butt for sure. Set the whole weekend aside.
bought from Terrapinmfg. Was on back order for awhile.
precision fit though.
when I installed it took some work to get it aligned properly, I installed some screws in what holes I could while I gradually got other holes aligned.
once in and all tightened up , everything put back in it was moment of truth.
truck fired up first crack!
