Aerostar Ford Aerostar
Battery
Old Oct 9, 2018 | 03:21 PM
87&97Aerostrar's Avatar
87&97Aerostrar
Battery
What are you guys with the older Aerostars doing for a battery. It's supposed to use a group 64 and nothing else seems to fit like it's supposed to, mainly because the height doesn't match the hold down rods. I've been told by two places that sell only batteries that it isn't made anymore.
The only solution I see is to get a battery box from a later model and try to find a battery that will fit that box with the terminal posts ending up on the correct side.
Has anyone ever done this? Is it pretty much a bolt on project?
Old Oct 9, 2018 | 05:26 PM
Jose A.'s Avatar
Jose A.
what? I don't have any problem getting batteries.
Have you been to an Interstate dealer?
Over here in Florida there is an Interstate store where you take your old battery and they sell you a remaned one for $50.00. I've had good luck with those remaned, they last a lot longer than a new one.
Old Oct 9, 2018 | 05:58 PM
xlt4wd90's Avatar
xlt4wd90
Not sure where you are, but a casual search turned up the Pep Boys in Ft. Lauderdale has at least 1. It's a Champion, pretty good brand and at $25 discount right now.
The later model Aerostars used group 65 batteries, which are shorter but wider and deeper.
I've had mixed results using remanufactured batteries, so it's kind of a crap shoot. Just make sure to keep your receipt for warranty replacement.
Old Oct 9, 2018 | 06:01 PM
ford390gashog's Avatar
ford390gashog
Quick search for group 64, napa, autozone, advance and walmart all have them. Should not be hard to get.
Old Oct 9, 2018 | 06:32 PM
87&97Aerostrar
I don't have any problem getting one for my 97 either, but it takes a group 65. My 87 takes a group 64. I can't use the 65 because the posts are reversed and the cables won't reach. I'll be passing an Interstate dealer later this week and I'll stop in, but their web site pops up a group 56 for my 87 and I want more amps than a 56 provides.
Old Oct 9, 2018 | 06:55 PM
87&97Aerostrar
Don't believe everything you read on a website. They all have them until you walk into the store and try to buy it. Then they say the replacement for that is a 56. Autozone, Advance and Walmart do not have this battery. I will check NAPA tomorrow, but I won't get my hopes up.
Old Oct 9, 2018 | 09:10 PM
ford390gashog
https://www.napaonline.com/en/p/NBP7564
Old Oct 10, 2018 | 11:59 AM
87&97Aerostrar
I just came from the NAPA store and they can order it, if I want one that's been sitting on the shelf for three years. I'm just going to change the battery box because I will have the same problem every time I need a new battery.
Old Oct 10, 2018 | 03:31 PM
xlt4wd90's Avatar
xlt4wd90
If possible, get the tray from a later model Aerostar so you can use the group 65 battery. It's a lot more common.
As I said, it's shorter, but it is wider and deeper than the model 64.
Old Oct 10, 2018 | 06:34 PM
87&97Aerostrar
Can't use a 65, terminals are reversed. Cables won't reach.
I'm pretty sure a 27F will work.
Guess I'm off the the junk yard. Hope it isn't too muddy.
Old Oct 11, 2018 | 12:11 PM
Car Guy's Avatar
Car Guy
I had this same problem with an ‘87 Aero of mine. Don’t remember the specific battery (group) I used but remember slightly readjusting the cables to make a regular terminal work. As best I can remember this didn’t require a lot of work and was rather easy.
Old Oct 11, 2018 | 01:59 PM
xlt4wd90's Avatar
xlt4wd90
I think there is also a version of the model 65 battery with the terminals reversed. Maybe it's model 66. Best to go to your local auto parts store to check.
Old Oct 13, 2018 | 12:25 PM
87&97Aerostrar
Before heading to LKQ this morning, I decided to just see if the 27F battery would fit in the 87's tray. It's a real tight fit and that is one heavy battery. I had to wiggle the battery to get the hold down rods hooked to the battery tray and scrape what was left of the plastic coating from the inside of the piece that goes across the top of the battery but I managed to get it secured and hooked up.
Rusty_S
Dec 27, 2021 10:14 PM
labman1014
Aug 9, 2013 05:26 PM
ATLoffroad
Oct 24, 2007 10:47 AM
RDON
Electrical Systems/Wiring
Jun 5, 2007 01:22 PM
seawulff
Aug 29, 2005 04:11 PM
