76 302 dipstick
Old Sep 25, 2003 | 09:32 AM
okiebronco's Avatar
okiebronco
76 302 dipstick
did 76 ford truck 302 engines have the dipstick tube that screwed into the engine oil pan (like a tranny line screws into a tranny). the reason why i ask is i need to find one for my 76 bronco but none of the parts houses around here carry it. i even tried obxolete ford here in oklahoma city and they just looked at me like i was funny
Old Sep 25, 2003 | 09:34 AM
okiebronco's Avatar
okiebronco
hope the pic helps. on the right you can see the screw in piece im talking about
Old Sep 25, 2003 | 01:44 PM
ecarter50's Avatar
ecarter50
302 in a pickup has dipstick in the timing cover. I have used brake tubing to make dipstick tubes. Make sure the dipstick goes into the pan same distance as stock.
Old Sep 25, 2003 | 05:49 PM
f100guy's Avatar
f100guy
what is wrong with that dipstick dube. if it stripped just clean it and the block and use jb weld. that stuff fixes everything
Old Sep 25, 2003 | 09:01 PM
fordtrks4fr's Avatar
fordtrks4fr
i am figuring someone did a swap on you. if it is the double sump pan out of a mid 80's car it will fit a truck, mine cleared my 79 with a 5.8. kinda funny actually, i had two dipsticks, the stock location in the cover and the one in the pan...lol. in stead of tracking down the 80's app u need i would take the advice to use a bit of brake tube or u can even just replace and reflare the end of your old tube if u only remove the flare
