Hi all,
my 1994 E350 IDI 4WABS is liting up the ABS lamp now and then. Found no system in this, and now I'm trying to retreive the trouble codes. (Checked almost everything, I think...)
But that is not easy...or what?
Searched the net for code scanners that can do this on this model, but found NONE. (What do the pro's use??)
So no I need tips. On the RABS systems there is a way to short a cable and get blink codes, but I don't think this works on this model with 4WABS. Want to do it myself, my trust in the pro's is low these days....
Okay, if my understanding of the 7.3s computer is correct it's EEC-V, under hood there will be an emisions sticker, it will tell you what computer you have, post that and we can give you some better help. You may have to pay the FORD garage to scan it. It could be there is a seperate computer for the 4wabs.
from what i can obtain from the Chilton repair manual it is a static test completed at the RABS II module for rear wheel or the ABS module for all wheel anti lock. and has to do with the static lights in the dash ie the Brake light and the abs light one being red and one being yellow. I am still researching this info as to the fact that I am having a problem with my RABS i have had the spring removed from the dump valve and have as of yet to get the proper info from the repair shop.
