Where does the fuel pump get its command from
Old Oct 8, 2018 | 05:32 PM
F350-6's Avatar
F350-6
Originally Posted by Hesson81
What relay is in the pcm? The fuel pump relay? I'd like to know because I just sent off my pcm for testing, I can ask them if they test that relay. ..if so, they probably change it.
Apologies. I meant to say the relay is integral to the fuse panel, at least on the 02-03 models. The way I tested was to run a jumper wire from the battery to the fuel pump to verify the pump was good and the truck would run. Then I checked for voltage immediately after the key was turned on at the fuel shut off switch in the passenger kick panel. Then traced the wire back to the fuse panel and ohmed it to verify the wire was good. Found power going into the fuse panel but not coming out so I bypassed it.
Sorry again for the confusion.
Old Oct 8, 2018 | 06:47 PM
Hesson81's Avatar
Hesson81
Originally Posted by '88 E-350
A fuel pump relay is extremely unlikely to cause an intermittent miss, so unlikely that I'm tempted to say it's impossible to be the cause.
yea. .from the sounds of it you're probably right. I think my problem is going to be injector wire issues. .I haven't been home to test it. Next step for sure
Old Oct 8, 2018 | 06:49 PM
Hesson81's Avatar
Hesson81
​​​​​​thanks for following up. . I just know with this intermittent power loss or misfire on one or 2 occasions, I'm pretty sure I hard clicking (relay)!coming from the fuse box.. may don't know where. .,that could also be a ground issue as well.. I don't know
Gicknordon
Dec 12, 2017 06:26 AM
ster1
2004 - 2008 F150
Jan 25, 2014 02:00 PM
Smokey1961
1997 - 2003 F150
Sep 8, 2011 10:14 PM
seedpress
1978 - 1996 Big Bronco
Sep 9, 2010 09:48 PM
Izzy
1983 - 2012 Ranger & B-Series
Nov 8, 2004 04:37 PM
