fuel filter/separator
Old Sep 25, 2003 | 07:04 AM
fatbob's Avatar
fatbob
The last few times I tried to drain the separator I got little or nothing out the drain line. The last time I even had to remove the filter cover to get the drain to work. The lever would rotate, just nothing would come out the drain line. Once the cover was off it drained fine. Has anyone else had this problem?
Old Sep 25, 2003 | 08:51 AM
johnsdiesel's Avatar
johnsdiesel
Yes. Some will recommend that you drain the fuel bowl with the engine on. There's absolutely no reason to do this and it isn't as safe as doing it with the engine off. Every time I drain my fuel bowl I unscrew the lid. Since the fuel bowl is sealed, you need to let some air in through the top to allow the fuel to move.
Old Nov 30, 2003 | 02:17 PM
johnnykool6's Avatar
johnnykool6
I was told to open the drain lever, then turn the key on for 5 to 10 seconds, than off again, and close the lever. This works good for my '99 with electric fuel pump.
Old Nov 30, 2003 | 06:17 PM
Quadzilla's Avatar
Quadzilla
When I open the valve, if nothing comes out, I leave the valve open and "bump" the starter once, and the juices start flowin'. As recommended above, don't run the engine while draining.
Old Dec 8, 2003 | 06:10 PM
Hunt1's Avatar
Hunt1
Where is this located on a 2001 PSD? I am really new with diesels and want to do some of the stuff myself. Also...how often do I need to do this?
Thanks!
Old Dec 8, 2003 | 06:14 PM
Shake-N-Bake's Avatar
Shake-N-Bake
It's on top of the engine, right under the plastic cover that says "PowerStroke". For your first time, you might want to remove the plastic cover to help you see what you are reaching for back there. After you do it once, you'll be able to reach the lever without removing the cover.
Most people suggest draining the water during each oil change.
Old Dec 9, 2003 | 07:07 PM
ekb's Avatar
ekb
I just had to replace the fuel heater that is located in the bottom of the filter / seperator canister. There is a space of about an inch deep under what looks like the bottom of the canister there was a lot of gunk down there! I drain the water every time I change the oil. If your having trouble draining the drain hole 9less than 1/4" may be clogged.
Old Dec 11, 2003 | 02:02 PM
thinksnow's Avatar
thinksnow
waste fuel
When I drain mine the diesel runs all down the side and all over the driveway. I put a oversized drain pan under there in a failing attempt to catch it all. Im I doing something wrong here? Is there a better way?
Old Dec 11, 2003 | 03:04 PM
1BADF350_4XCREW7.3's Avatar
1BADF350_4XCREW7.3
I've been thinking about extending the line over to my driver's side leaf spring so I can use a small can to catch the cup and a half of fuel... too lazy, but now that winter is here...
Old Dec 11, 2003 | 03:13 PM
Shake-N-Bake
Re: waste fuel
I did that the first time too. I have to admit though, it looked pretty cool watching the water bead up over the surface of the fuel as it ran down my drive way. (yeah, I know....I'm pretty sick.)
Take a small piece of fuel line and keep it with your oil changing stuff. During every oil change, slide the hose (fuel line) over the tubing and let the fuel drain into the oil drain pan. I drain out the whole cup or two that is in the fuel filter.
