Sponsored by: Real Truck
Front Axle does not engage
Old Oct 7, 2018 | 05:59 AM
JDJR59's Avatar
JDJR59
2016 F250 6.2
Front hubs are set in auto mode
When I turn the **** in the truck to engage 4 hi or 4 low the front axle does not engage. I have to get out and manually lock the hubs. What should I be looking for to correct this problem
Old Oct 7, 2018 | 06:41 AM
seville009's Avatar
seville009
Vacuum issue most likely.
Are you still under warranty? If so, have Ford fix it.
If not, can always just leave it alone and just manually lock them. That’s what I do.
Old Oct 7, 2018 | 08:18 AM
xcrsp440's Avatar
xcrsp440
There are a couple good videos on diagnosing ESOF problems. Go to YouTube and do a search.
Old Oct 7, 2018 | 10:44 AM
leadmic's Avatar
leadmic
Mine turned out to be the vacuum solenoid on my 2011. It was an easy fix..
Old Oct 7, 2018 | 03:10 PM
Ron94150's Avatar
Ron94150
I've had to fix 2 vacuum line leaks on my 16 f250. They weren't worth going to the dealer for. But the dealer did have to replace both spindle seals. The truck is out of warranty now, and it's not auto engaging again. Luckily, the spindle seals have a 12k/12 month warranty. I found both my vacuum line leaks pretty easy, but a smoke machine is needed to diagnose the seals.
Old Oct 9, 2018 | 06:33 AM
Paul_inCT's Avatar
Paul_inCT
You can just get a vacuum gauge and work your way down (or up) the line. I pulled the line of the reservoir and could hear the vacuum. So I reconnected it the pulled the line off the back of the hub. Plugged the vacuum gauge in. No vacuum felt down the line and found the passenger side was crispy and brittle near the exhaust. I went to auto parts store and picked up 3 feet of line and some fittings (cheap). Replaced the the line got reading on the gauge. Put line back on the hub 4x4 success . I'm going to replace the other line where it goes of the frame rail near the exhaust manifold. My truck is an 07 and I'm sure both those lines went thru quite a few heat cycles.
Old Oct 10, 2018 | 06:44 AM
cmaupin's Avatar
cmaupin
sounds awesome do you know the size of hose you replaced
Shorty Thompson
Jan 14, 2019 08:20 PM
polarlys
6.7L Power Stroke Diesel
18
Nov 23, 2015 12:49 PM
ssknightrider
Aug 23, 2010 09:44 PM
V10FORD4X4
Nov 17, 2004 08:21 AM
ranger owner
1983 - 2012 Ranger & B-Series
Dec 16, 2003 07:56 AM
