Tail Lights Do Not Work! I'm Stumped!
Old Oct 5, 2018 | 12:06 AM
Birkin Sornberger's Avatar
Birkin Sornberger
I didn't see your original comment, no I don't have a test light and that's not what my ground looks like. I can take a picture tomorrow of the harness & ground if that helps.
Old Oct 5, 2018 | 07:04 AM
subford's Avatar
subford
You may want to check or run a wire from the NEG post of the battery to the frame.
The frame is insulated from the body by rubber so if you do not have a wire (10GA) running to the frame from the battery neg post it may only be a grounded intermittently.
Old Oct 5, 2018 | 07:58 AM
Birkin Sornberger
Ok sounds like a plan. When I get home I'll run a wire to the frame of the truck and see how that goes. What if I literally ran a wire around the truck from the battery to the harness? Would this give the same effect while I'm trying to diagnose the problem?
Old Oct 5, 2018 | 06:27 PM
Birkin Sornberger
Welp, I've done what subford recommended to no avail. All lights still work aside from the brake lights. I've checked just about everything in the system that could be a problem and I'm honestly at a loss. The only possible (not really) thing it could be are the bulbs, which still both contain two undamaged filaments. I don't know why this would be the problem, but it's the only thing that I can think of at this point.
Old Oct 6, 2018 | 08:39 AM
Diesel_Brad's Avatar
Diesel_Brad
AGAIN. do you own a test light?
Old Oct 6, 2018 | 02:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Post #16..........
Old Oct 6, 2018 | 02:13 PM
FORDF250HDXLT
That's a possibility, but it was working fine just a few days ago so I'm really not understanding how all of a sudden the ground would be bad. Do you know if that's the only ground wire, any ideas..?
That doesn't matter.Eventually,every item will fail on a vehicle and at some point it was working fine the day prior.Remove that ground wire,take and clean up the frame where the screw goes into,clean up the ring terminal,then apply some grease to the area and screw the screw and wire back in.Chances are high the issue will be resolved.
Be sure to remove the bulbs,spray the sockets with electrical cleaner (WD-40 does work pretty good too,I've used it when I ran out of e-cleaner) apply some bulb/dialectic grease and put the bulbs back in.
Old Oct 6, 2018 | 08:11 PM
Diesel_Brad
Get yourself a test light and multi meter
Old Oct 6, 2018 | 08:40 PM
Birkin Sornberger
Thanks for the help everyone, in response to @FORDF250HDXLTordf250hdxlt, I had already touched up the ground at the back of the truck and ensured the connector was nice and clean. The problem DID turn out to be that "ground" though. I tested it on a multi meter (I do have one Diesel_Brad btw) and there was resistance even on the bare metal I had ground down. So I said ok, that's probably my problem. There was a ground wire that runs with the harness to the front of the truck aside from this wire so I decided to give it a try without that cable connected. It works now. What I don't understand is how this problem all of a sudden sprung up. and if my frame really isn't grounded anymore, will that short any other components? I only bought this truck about 3 weeks ago and I've only owned cars so I'm pretty new to this.
Old Oct 7, 2018 | 08:23 AM
ZombieF150's Avatar
ZombieF150
The easiest way to make sure every thing is grounded is to ground it yourself. ground cab to frame and bed to frame then ground from battery to frame. I chased grounding problems all over a Chevy I had. I finally bonded everything together and the issues went away. Corrosion takes many forms,often caused by dissimilar metals being in contact with each other.
Old Oct 18, 2018 | 07:37 PM
Bri21074's Avatar
Bri21074
I also have a simaler issue but my abs light flashes 16 times. My truck has a survive body with led tail lights . The cab mounterd bake light is also out.
Could the ground also be my Isues?
Old Oct 18, 2018 | 07:51 PM
sandymane's Avatar
sandymane
https://www.fordf150.net/forums/viewtopic.php?t=32879 Lots of possible issues. Check this thread out for some good ideas for you. Sandy
Old Oct 19, 2018 | 12:32 PM
  #28
Bri21074's Avatar
Bri21074
My issue started after I had a short in my trailer. I checked all my fuses but I wonder if I fryed something
Old Oct 20, 2018 | 05:58 PM
  #29
Bri21074's Avatar
Bri21074
Pretty sure I found my issue, it’s the 3rd brake light on the cab
mofoco1
Jul 14, 2016 08:02 AM
jhaas63
Sep 22, 2013 05:24 PM
blackford97
Sep 5, 2011 10:28 PM
1997 f150 4.6l
1997 - 2003 F150
Mar 11, 2011 01:04 AM
1974oneton
Sep 15, 2009 06:44 PM
