bronco/f150 frame
Old Sep 25, 2003 | 12:07 AM
ctford24's Avatar
ctford24
bronco/f150 frame
9/25 12:35a
i am curious, does an '88 bronco have the same frame as an '88 F150 short wheel base? they look an awful lot alike. i am new to the whole truck scene, but i know a '79-'93 mustang like the back of my hand! thanx for any help!
Old Sep 25, 2003 | 12:54 AM
Jack01's Avatar
Jack01
I believe that they are very close in relationship since they use the same front end and the proceedures for repair are almost identical.....check with the specs on both the f 150 and the bronco.
Old Sep 25, 2003 | 01:09 AM
ctford24's Avatar
ctford24
i need to know so i can get a set of headers from ebay. what i really need to know is can you interchange headers between the two.
Old Sep 25, 2003 | 01:11 AM
Superdave's Avatar
Superdave
ctford24
Do you have project in mind? Swapping of some kind?
If so, someone here can probably also answer your question.
Feel free to ask more.
Old Sep 25, 2003 | 07:20 PM
fordtrks4fr's Avatar
fordtrks4fr
i am not sure, but i think it will be about a foot difference in length. i had friends do this swap with their gm products, one guy cut the front off a box and welded it back together. another guy used the blazer back and welded box front on. the pickup cab needed all new mounts in the back side. but i honestly never looked at the ford equivalent , not that there is one...lol. where i grew up i was the out cast driving beat up red fords pulled out of farm fields
Old Sep 25, 2003 | 09:08 PM
WhëëlMå1's Avatar
WhëëlMå1
The bronco and half ton F series are exactly the same when it comes to headers. They are the same exact vehicle to the B pillar.
Rich
Old Sep 26, 2003 | 12:56 AM
ctford24's Avatar
ctford24
thanks for the info guys!
Old Sep 26, 2003 | 03:00 PM
ctford24's Avatar
ctford24
i have a rebuilt 302 with gt-40p heads. i want to put in my 88 full size bronco, but headers are an issue with these heads. i think about any shorty header for the 'p' heads will work. i don't have a y -pipe or cat converters. so if they will clear the frame, i'm good to go!
