4x4 Vibration Issues
Old Oct 2, 2018 | 10:36 PM
jacampbell's Avatar
jacampbell
Hey there,
So here in Western Canada we were walloped with 40 cm (16 inches) of heavy wet snow today, and I figured it was a good time to take the 77 F150 4x4 out in order to get to work. However, I noticed a horrible vibration from the front of the truck. It only happens between 20 and 25 mph, and is noticeable when the truck is coasting, as in I don’t have my foot on the gas, and most noticeable when riding the clutch (yikes!) during these speeds. It is a quite severe vibration, and I’m just wondering where it may be coming from, it almost feels like the “warning” vibrations carved into the pavement coming up to a rural stop sign. It doesn’t appear when the truck is in 2wd, and it isn’t from the steering linkage, as the drag link and tie rods were just changed and the wheels aligned. The transfer case has been leaking recently, could it be low oil? Let me know what you think. Thanks.
Old Oct 3, 2018 | 12:12 AM
ford390gashog's Avatar
ford390gashog
Front u joints or a worn pinion causing the shaft to wobble under coasting.
Old Oct 3, 2018 | 07:16 AM
Jklnhyd's Avatar
Jklnhyd
I agree with ford390 gashog.
I would check the u joints, change the fluid in the front differential, and pull the front hubs and clean them up. Get that tc leak fixed.
Old Oct 3, 2018 | 10:01 AM
Pickupmanx2's Avatar
Pickupmanx2
Long bed, short bed? Had a carrier/center support bearing do that once, or also your C-bushings and radius arm bushings,,, let us know what you find.
Old Oct 18, 2018 | 06:49 PM
jacampbell's Avatar
jacampbell
Taking it into the shop tomorrow, will let you know what they find! I couldn’t find anything at home
aphotic26
Nov 11, 2018 07:36 AM
f15097
Jun 7, 2008 04:18 PM
beekermartin
1997 - 2003 F150
Feb 7, 2007 08:48 AM
WhiteBeast97
1997 - 2003 F150
28
Mar 17, 2006 12:58 PM
