1948-1950 dual wiper remedy.
The "nut" bushing pops off with little effort. Notice the snap ring groove on the end of the shaft?
My next move is to fabricate a connector arm from one side to the other. I haven't decided what I want yet.
I thought about a flat bar with the right sized oil-lite bushings. I also thought a mini tube with heim joints, but that might be overdoing the simplicity. Not sure yet.
The swingarm shafts are just under 1/4" diameter.
Hope that helps!
I measured from center to center of the shafts and got right at 16.5" Since the bellcranks are identical that should be a pretty good starting point.
A picture and measurement would make me a happy camper!
#28
The original is staked in. The new reproduction replacement has a set screw to secure it. If yours is slipping around the shaft, then the internal splines are stripped. The "missing piece" is the part the wiper arm slides over. It is either pot metal or aluminum. The shaft itself is steel.
Hope that helps!
Hope that helps!
Later!
Mr. Ed
#29
Jeff,
I managed to get some pics posted. I've tried this 3 times now and still can't get it right. I don't know what happened to my explanation the first couple of times...ugh.
Here are some pics of the 48-50 linkage set-up and then a 50-51 set-up.
The linkage piece for the 48-50 trucks appears to be approx. 3/32" thick and roughly 1/2" wide. It looks like its 16 5/8" hole to hole.
Bobby
Bobby
