Shifts funny.
Old Sep 22, 2018 | 08:00 PM
Howdy2's Avatar
Howdy2
Shifts funny.
Well, I finally got the starting issue fixed. Now, it is not shifting into 2nd or 3rd. It goes from 1st, winds to about 55 mph then shifts into overdrive. Now what? The truck is a '92/302 with an AOD transmission.
Old Sep 23, 2018 | 10:43 AM
sandymane's Avatar
sandymane
Run codes to see if they offer some insight. Sandy
Old Sep 23, 2018 | 11:17 AM
rla2005's Avatar
rla2005
Old Sep 23, 2018 | 01:28 PM
Howdy2's Avatar
Howdy2
No idea how to do that.
Old Sep 23, 2018 | 01:30 PM
sandymane's Avatar
sandymane
Try the fix in the video that RLA sent you. He has plenty of experience. If that doesn't work then I can send you a video of how to check codes. Sandy
Old Sep 23, 2018 | 01:55 PM
Conanski's Avatar
Conanski
Are you absolutely sure about that, what is the trans code on the drivers door pillar?
The AOD is all mechanical and if it is not shifting correctly the problem is going to be something mechanical is broken inside the trans, but I have never heard of one shifting 1st to 4th it is more likely to shift into a neutral where the other gears are supposed to be. The other 2 transmissions that were available for these trucks are computer controlled and they could potentially make this shift pattern if the computer senses something wrong, that doesn't rule out something being wrong inside the trans but there could also be an electronic cause for it. So first lets figure out exactly what trans you have and then proceed to pulling codes if it turns out you don't actually have an AOD.
annaleigh
Jan 31, 2018 04:51 PM
LARIAT 85
Sep 7, 2016 01:22 PM
THE BLUE HEAP
Jun 24, 2013 04:10 PM
broncobasher
Jun 6, 2004 07:52 PM
suzukiriderman
Feb 20, 2004 01:21 PM
