20 in Lariat wheels on an XL
Hello FTEs!!
Just bought a 2018 F250 XL and acquired a set of take off 20 in Lariat wheels and tires as well as a fog light included front bumper. TPMS sensors were transferred and wheels/tires balanced and installed today; Drives like a dream!!!
So I see I need to update for wheel diameter but not a clue about how; I have read the posts about FORSCAN and see the APP and OBD2 plug in so more post reading for me!!
Any known issues with changing the wheel size other than the speedometer update? The XL does not offer this size wheel/tire as an option so thinking there may be something hiding somewhere I should know about...
I also read that I need to make FORSCAN changes to get the fog lights to work correctly so THANK YOU for posting all the info and I will be spending lots of time searching and reading these awesome posts as well as asking lots of questions!!
FYI, I do have the fog light connector on the drivers side frame rail and plan to install the bumper soon so a few more pics to come.
Your dealer can reprogram your truck for stock tire sizes:
https://madocumentupload.marketingas...3372f&v5=False
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Gearing...........you're fuel mileage will go down. that's the only down side. But truck looks great, way better than stock XL wheels.
Edit: I assumed it was a diesel. Not sure what gear selection gas trucks have. I know on diesels, the XL trucks are not geared to run factory 20s.
Gasser as I could not justify the price increase for the diesel; I have 3.73 rear axle gears and one calculator puts the new ratio with the increased tire diameter at 4.04 so MORE reading to see what that is going to do but I can give up a little mileage to look good... The wife likes it so that's more important!!
Shouldn't be a problem as a lot of 6.2s come with 3.73 and 20" wheels, mine did. I was getting 13.8 mpg average on the stock 275/65R20s and now average 12.6 mpg with 37x12.50 R20s...
What do you mean (XL trucks are not geared to run factory 20s)? I thought all SRW trucks had either 3:31 or 3:55. My XL came with 18" wheels and 3:55 gears. I found some 20" take-offs and had the dealer make the change for the larger wheels. Works a treat, looks good too!
Thanks '18 F250 4X4! I really like the machine wheels you picked, I think I would have jumped on a set too! But after 3 months of keeping an eye out for take-offs in Maine its clear, the pickings are slim. Happy I found a set for a fair price, well fair price for around here anyway. Also I 'm getting old and really like chrome...don't tell anyone!
Adding a larger diameter wheel results in a numerically *lower* ratio, which means you have less pulling power. It also means the speedometer will read slow, and your odomoeter will not show all the miles you've actually driven. The fuel economy display will read less mpg than what you are actually getting.
FORScan or the dealer can fix the tire size issue through a simple reprogram. Your 3.73 ratio is fine for that size; as others have pointed out, you can option a gas Lariat truck with those tires and that gear ratio. It will pull less hard and be a hair slower than it would be on the standard 17" size, however. Fuel economy might actually improve...lower numeric gear ratio...at least empty on the highway.
Amazing how a new set of rims transforms an XL truck. Both of the trucks pictured look great!
