Fuel flow meter..
Old Sep 16, 2018 | 01:17 PM
gman97005's Avatar
gman97005
Fuel flow meter..
I'm pondering the use of a fuel flow meter to calculate miles per gallon but realized this probably won't work with EFI because the fuel pressure regulator uses a return line, am i thinking correctly ?
Old Sep 16, 2018 | 03:43 PM
Conanski's Avatar
Conanski
Yes. If you want an fuel milage calculation based on fuel delivery you need to get into the PCM and use injector duty cycle, tuner software typically does this as part of the package.
Dakotaboyd
Apr 18, 2018 04:51 PM
86bluebronco
1978 - 1996 Big Bronco
17
Jun 24, 2010 09:39 AM
Shade
Jun 28, 2008 09:03 PM
javaelina
Nov 19, 2004 01:14 PM
Tadashi
General Automotive Discussion
May 25, 2004 06:15 PM
