Tailgate malfunction
Old Sep 18, 2018 | 08:23 AM
jergle's Avatar
jergle
Y'all are making me smile every time I open my manual tailgate! It just isn't that difficult. Push button tailgates sound like a solution in search of a problem.
Old Sep 18, 2018 | 09:40 AM
delorenzomp's Avatar
delorenzomp
Qs : (A) does the connector in question (drying/greasing) control anything other than the tailgate? (B) Can the connector be 'disabled' with the tailgate being opened manually? (C) Does this 'power' tailgate come on the XL version? ...also, one unrelated question, does the truck start with a traditional key (or the keyless pushbutton) ? Thank you.
Old Sep 18, 2018 | 10:04 AM
Mlambert22's Avatar
Mlambert22
you are exactly right, I'm waiting for the time that my tailgate either wont go down or goes down on top of something and smashes them both..
Old Sep 18, 2018 | 06:39 PM
VoodooRob's Avatar
VoodooRob
2017 F350 6.7 My connectors are on drivers side behind spare tire. In reality one connector is for the tailgate one is for the camera, stuff both full of dilectric grease. Both plugs were full of water and starting corroding a couple weeks into ownership.
Old Sep 18, 2018 | 06:55 PM
delorenzomp
An added, although possibly redundant, step is to ( after cleaning, drying, dielectric greasing) coat the joint with StarBrite Liquid Electrical Tape. It is an anazong product for such outdoor applications.
Old Sep 18, 2018 | 07:01 PM
cficare's Avatar
cficare
Originally Posted by Blwnsmoke
A simple fix would be that if the truck is not in park, the tailgate is disabled electronically from opening.
I like it. Now if we can convince Ford to offer a reflash with that algorithm. I'd be happy if the tailgate would open only when the engine is not running.
Old Sep 19, 2018 | 04:56 AM
rwilimo's Avatar
rwilimo
Dielectric grease while being a great product will not fix this long term, if you are having water entry why not have the dealer install the updated parts so you have along term proper repair?
Old Sep 19, 2018 | 05:32 AM
delorenzomp
rwilimo, is there a TSB on the subject?
Old Sep 19, 2018 | 06:01 AM
rwilimo's Avatar
rwilimo
I do not have the number handy but yes there is, it calls for complete main harness replacement and any damaged pigtails in the rear.
Old Sep 19, 2018 | 07:48 AM
delorenzomp
That is good to know, thanks
Old Sep 19, 2018 | 04:46 PM
VoodooRob's Avatar
VoodooRob
TSB production dates did not cover my model. Dealer had the truck and could not duplicate the problem so no issue found according to them. Its on me to fix a 1 month old truck with a tailgate dropping when the harness gets wet. Dilectric then seal the plugs is going to last a long time, 100% fixed my problem.
Old Sep 21, 2018 | 02:10 AM
hobbie1's Avatar
hobbie1
I have had this occur a few times on my 2018. I tested by trying to trigger the tailgate while moving and standstill when not in park. It will not open. I'm pretty sure that both times that the tailgate opened my thumb bumped the button on the dash when releasing the parking brake. I plan to go in and disconnect that switch as I have no reason to use it. I open the tailgate with the button on the tailgate and or two clicks of the remote.
Warpburn
Aug 23, 2018 08:29 AM
finnf250
Feb 22, 2017 07:20 AM
MDSavage
Jan 23, 2013 07:39 AM
mr2000
Mar 4, 2009 07:44 PM
xyz1406a1
13
Sep 27, 2005 10:49 AM
